How many miles did your (A-SPEC) Yoko AVS ES 100's last?
My dog thinks I'm Elvis!
1 Post
I just happened to notice this weekend my rear tires were beyond their wear markers after only 6000 miles. The fronts are not far behind. I haven't rotated them because I haven't reached my second service yet. 80% of my milage is related to my daily commute to work that is ~4 miles one way all downhill and uphill on the way home over curvy, mountain roads in poor condition. And I do drive the car hard but no laying rubber or hard braking. Despite that, the wear seems excessive. What have other's gotten with the A-SPEC Yokahama tires?
i have 13000 miles on my Yokos and my fronts need replacing....their not bad bad but noticeable, they already been rotated once at the dealer. But i love them and plan on gettin new ones but in 245's cause i think the 235s are alittle to narrow and dont give the rims and car the right look. thanks
travis
travis
Photoshops, and Polls!!!!
what are you guys doing????????????
i have 13000 miles and my yokos are far from being replaced...
are we talking about the same tires here? these are the aspec tires z rated right?
i think i can easily go to 30k miles maybe 40k
(i keep my tires properly inflated fyi, are you?)
1 Post
Yes they are the OEM A-SPEC tires Yokahama AVS ES 100 235/40/18 and I check my pressures monthly and keep 40 psi in front and 37 psi in back (recommended is 39 in front and 36 in back). I guess I'll have to slow down on those curves. Interestingly, I've not yet rotated my tires (6000 miles) and the rears are more worn then the fronts. I'm replacing them with Falken ST115 245/40/18.
professional TL driver
travis
travis
-Hey ONAGER will 255's rub at all? Or will they look alittle too wide for t he 8.5's? Ive never seen them on the a spec rims before.
Licking Platters Clean
Is this PSI recommendation specifically due to the Yokos or any TL with Aspec suspension and 18's? I don't have ASpec rims or tires, but I do have the suspension on Ronjons and Falken ST-115s. Thanks!
1 Post
Originally Posted by SBTL
This is the recommendation from ACURA printed on the sticker inside the drivers door on A-SPEC equiped TL's (39 psi front 36 psi rear). By the way, I just put in an order for Falken ST 115 from Discount tire. I hope they last longer but at $123/tire + ~$45 shipping and no tax, at least the price is right.
How are the Falkens in term of handling? I love the way the yokos stick. i have the falken azenis on my civic and it sticks like glue, how are the st 115? Thanks
Travis
now if the car is lowered? honestly i dont know... they shouldnt as nothing else but the ride height changed... but untill i got under the car and chaeck the clearence i couldnt be sure....
my car isnt lowered and even if i did i am probably going with the aspec kit (i like it to be mild) as since the drop is so small it probably wouldnt rub either
http://www.tirerack.com/tires/Spec.j...omCompare1=yes
here are the specs on the tires i am looking at.... and if you read they can be used with an 8.5 inch rim
most here agree that 245s dont give enough protection to the rims.... barely cover it
1 Post
Travis
Travis
