Help.. rubbiing issue
Old Apr 23, 2009 | 11:23 AM
disguy's Avatar
I had a set of Sevas S22, offset is 25m in the front and 40m and the rear, Im rubbing on very lil bump in my front tires, front tires are 245/35/20. What can I do to fix this?
Old Apr 23, 2009 | 11:37 AM
TLdriver022's Avatar
roll the fenders
Old Apr 23, 2009 | 12:52 PM
Fulani has a TL's Avatar
First issue is your 245/35/20 Should be running 30 series not 35, also is it 8.5 wide up front? If so, run 225s. 245 is too fat of a tire as well.
And as noted above, roll your front fenders, it will cause a slight flare which will help.
How low are you?
Old Apr 23, 2009 | 01:17 PM
disguy's Avatar
How low are you?
Well I had 30 series but I crack both front rim so i thought 35 would give me more rubber and protection, and yes they are 8.5 up front.. isnt 225 kinda of small for a 8.5 rim?
Old Apr 23, 2009 | 01:26 PM
bukjoe15's Avatar
Originally Posted by TLdriver022
roll the fenders
What does roll the finder means?????
Old Apr 23, 2009 | 01:39 PM
bukjoe15's Avatar
^^^^^ NVM i found out that is scary
Old Apr 23, 2009 | 01:56 PM
luckyAKAhappy's Avatar
My baby's ride...
^^LOL. Get smaller wheels with a higher offset along with proper profile tires. You won't rub, won't have to roll fenders and it'll handle better. And yes, 225 tires are skinny for 8.5 inch wide wheels but there are people who love that here and will give you mad props for having them.
Old Apr 23, 2009 | 04:24 PM
Maddizm's Avatar
try some thinner and lower profile tires...
Old Apr 23, 2009 | 07:59 PM
disguy's Avatar
I try thinner and low profile tires , and I crack my 1st 2 front wheels
Old Apr 24, 2009 | 07:12 AM
dtan1691's Avatar
Try 225 45 20 tires that would give it a nice stretch
Old Apr 24, 2009 | 08:13 AM
Maddizm's Avatar
Maybe it wasn't as much a tire issue as it was a wheel issue? You're talking about the Sevas S22s right? Someone with experience can chime in with those. But from what some have said some of those sets of wheels had QC issues. Again, others that have experience with them can chime in.
Old Apr 24, 2009 | 10:07 AM
bigmoetl1's Avatar
wdp skyhawk
you need to run a 245-30 or a 235-30 and they wont rub as far as sevas go they have had issues cracking but just avoid the potholes you wanna ride big wheels you gotta be prepared to deal with low pro tires and all the issues
Old Apr 24, 2009 | 01:21 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
also run the tires at a 40 psi pressure... I've had low profile tires and daily drive through the NYC 5 boroughs without an issue...
Good Luck...
Old Apr 25, 2009 | 08:13 PM
TLheaven's Avatar
Shyne
225/35/20 (moderate stretch) should help solve that problem and like everyone else said get your front fenders rolled.
Old Apr 25, 2009 | 09:50 PM
Maddizm's Avatar
Good Luck...
40? That's not too much? I mean if that really helps I'm going to do that. I usually run at about 34... or is that too little?
Old Apr 25, 2009 | 10:13 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
get a wheel with a higher offset ONLY SOLUTION
Old Apr 25, 2009 | 10:24 PM
TLheaven's Avatar
Shyne
He's saying if you run stretched tires put in 40PSI.
Old Apr 26, 2009 | 12:43 AM
Maddizm's Avatar
^ Well I'm running 235/30 on 20x8.5 is that considering stretching? Or not really? Yeah to the OP after a reread... 25mm might be too low an offset. but i dunno
Old Apr 27, 2009 | 10:30 PM
tonyc994's Avatar
6th Gear
what kind of places roll the fenders??
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
