Help front tires making noise after rotated
After i rotated the rear tires to front, the front tires make loud noise compared to be4. I running supercup kit with Bridgestone Potenza re01. Please help!!!!!
Registered but harmless
Received 1,102 Likes
1) live with the noise,
2) rotate the tires to their original position,
3) get the front tires shaved [this may be more $ than it is worth] and hope it was just tread feathering causing the added road noise, or
4) get new front tires.
check your alignment. good chance your rear camber is out and will probally need adjustable camber arms. I am a service advisor at my acura dealership and see this alot
Chances are the toe is out and the tires are feathered slightly, therefore the noise. Camber wear usually won't cause the noise as the tires are worn down on one side, but smooth tread still exists. This is the reason I wanted the OP to run his hand acorss the tread to check wear pattern.
Oakes
Wash & Wax
10-12-2015 11:17 AM
nuldabz
09-03-2015 05:49 PM
