Im replacing my front lower control arms because the compliance bushings are toast. I know you can press them out but I just wanted to replace the whole thing. Now the stupid lower ball joint doesn't want to come out. I used penetrating fluid, banged the control arm with a sledge hammer, used a ball joint separator and nothing. It looks like the joint separator tool is damaging the bolt and I don't want to do that. Any ideas?
So the freaking ball joint didn't come out so I took off the other bolts attached to the frame and bam big mistake the freaking axle joint came out. Now it's even worse, it won't go back in and the control arm won't line up. Now I might have to get the car towed and take it to a mechanic.
To free the ball joint block the control arm on one side with the sledgehammer (metal part) (x) then hit it on the opposite side (x) with a hammer. Be sure to wear safety glass.
The axle will go back in. It's held in place by a C clip. The C clip is attached to the end of the axle. All you need to do is line up the spines and it will snap back in place.
Use FIRE!!! and put the nut back but flip it around so that the non castle looking side is facing the tool on the lower ball joint and then use the tool. This will save the threads
Use the jack to push up against the control arm to reset it back into place since you are fighting the compression of the spring and shock. Don't freak out. have a quick smoke or beer and then think through it
Thank you, I didn't know what to do because I've never taken off an axle before, I guess I'll take off the spindle nut and it should pop right out? line it up and put it back in. As for the ball joint I'll try the sledgehammer again if not I'll use a fork ball joint popper tool. I didn't want to damage the ball joint rubber boot but it seems like there's a lot of play in the ball joint, maybe ill replace it too. It looks like most after market lower ball joints don't have a castle nut with the pin for safety, maybe I should get an oem one.
Well thank you so much for all the help, I tried the ball joint popper tool again from harbor freight and it finally came out. Did not use a blow torch. I was able to put the axle back in place after this and went ahead and installed a new lower control arm. But not without damaging the rubber boot and the threats on the ball joint which I will have to replace later. I was able to get the castle nut back in not all the way tho but most of the way until the ball joint bolt started turning on me. For any body that wants to do this do your research and don't take out any other bolts unless your able to take out the lower ball joint first. Don't forget you can rent your special tools at your local auto parts store, it helped me a lot. Now to figure out how to replace the lower ball joint and to get the nut all the way in without the bolt turning on me.
No it didn't damage the boot just move it up with a flat screw driver and grease it on the outside, just leave the castle nut on so you don't damage the screw. What damaged mine was the old style ball joint fork tool which didn't really help. As for the castle nut its about 2-3mm away from the LCA, I was able to put the safety pin back in. I'll try an impact gun to see if it will go all the way in, I just have to go buy one. I check it everytime I stop just in case, Ill just drive slow for now until I get the new LBJ and nut in the mail.
hmm, the threads must be pretty bad if you cant get on the last 2-3mm without turning the bolt. usually its not supposed to get that hard to turn unless the threads are seized/deformed, or if you are on the last half thread or so
Here is a suggestion. Jam a pry bar between the LCA and the hub arm and have someone stand on it while you tighten it by hand. It should put enough pressure on the nut where it will grab and not spin. I had that issue also on my LBJ. I end up replace it anyways since there was too much play
They are bad and deformed but for now it will do.
Ball joint nut usually need to be tighten with an impact gun bc the ball joint spins.
One can put pressure on the ball joint by jacking on the ball joint or control arm. Depends on which one is at the bottom/accessible. The tighten the nut.
Or take it to a shop for tightening.
FYI: When R&R control arm you need to preload the control arm first prior to tightening the mounting bolts. Meaning lift the car by the suspension so that the car is no longer in contact with the jack stand (just a little), with safety in mind. Then tighten the control arm with the suspension preloaded.
This will prevent the bushings being pre torqued/twisted and wearing out prematurely. One side at a time or both sides at the end.
here it is again. Can you believe that both guys do the same thing but neither of them show what they are striking! Its a mystery but the answer is right there. haha Thats for the video people.. right? haha
