Handling Question
Old Mar 11, 2007 | 09:32 AM
MichaelBenz's Avatar
CTS-V Import Slayer
Handling Question
I autocross my car frequently....having problems with the ever so prevelent PUSH into the corners. At high speeds...the car just pushes into every corner badly....I am constantly fighting it. I have upgraded CT rear sway, CT shocks and springs, ect. What my thought was is to upgrade the tires for racing purposes only (track tires) to some Toyo R-888 tires all around. Now here is where I get confused.
I was talking to a guy the other day that is a veteran autocrosser and he is telling me NOT to upgrade all four tires...but to just do the fronts...and leave the backs with the current tires (YOKO) as this will cause the back end to loosen up a bit helping the car turn into the corners better and not push so badly. What is your guys thoughts on this? I was gonna do all four...not accustomed to running different tires like that...but in theory...will this work?
There is another guy I was talking to last night...he says...NO...Dont do that. Just get some good general autocross tires and work on your techniques more. He says...you are overdriving the cars abilities and trying to make the car catch up to you....which it may or may never do or be able to do - so slow it down a bit here and there and work on smooth techniques to save time and cut seconds.
All said and done...what do you guys think? I havent dont anything yet....but am just contemplating the theories here and which way to go. I see some validity in both trains of thought to some degree.
Old Mar 11, 2007 | 09:48 AM
kennyc's Avatar
not vtech... VTEC!!!
are you running competitively or just for fun?
reason being there are things that you should not touch if you want to stay in the lower classes.
but if you just run it for fun I would recommend getting either narrower rear tires or wider fronts to neutralize the understeer. Rear will get less traction and that will make the car more willing to rotate.
Or you can find someone to make a stiffer front sway bar.
Old Mar 11, 2007 | 11:17 AM
01tl4tl's Avatar
Try a few runs with the rear bar disconnected
Also look into lower frame stiffner- See MrHeelToe in sponsored sales area
They take out some lateral flex and reduce push
Old Mar 11, 2007 | 03:26 PM
CTS-V Import Slayer
Thanks for the response. Yes...I am running competitively....or will be at the start of next season anyway. BUT....my class is already street mod or whatever...because I am supercharged...CF hood, ect....mainly the supercharger. I havent autocrossed with the supercharger yet...and am kind of expecting a whole different world here. Now so far as placing in my class...I will inevitably get eaten by EVO's and Scoobies that are in my same class with higher HP...but doesnt mean I cant attempt to pull off some respectible times anyway....maybe even hang...I dont know yet.
Old Mar 11, 2007 | 03:28 PM
CTS-V Import Slayer
Lower frame stiffener....hmm....I will check on that. Didnt know they made something like that for our cars.
Old Mar 11, 2007 | 03:41 PM
CTS-V Import Slayer
Those are not for 3G TL's . Dayum....they looked cool too! I was starting to wonder how that one slipped by me! They fit 2G TL's and TSX's. I wish that would be available for our cars too!
Old Mar 11, 2007 | 05:01 PM
tidus888's Avatar
Team Anthracite
not for us... its japanese cusco bars! =)
i wish they can make some for us... well.. there are 2 3G TL in japan i know =)
Old Mar 17, 2007 | 11:08 PM
bigmoetl1's Avatar
wdp skyhawk
the progess bar is 24mm and adjustable so that might help
Old Mar 18, 2007 | 11:14 AM
kennyc's Avatar
thinking out loud here... but won't the aftermarket suspension components for 7G accord works on the TL? Do they have more options?
Old Mar 19, 2007 | 12:06 PM
chill_dog's Avatar
Oderint dum metuant.
H&R makes a thicker FSB.
Old Mar 19, 2007 | 12:49 PM
Hardtimes's Avatar
I was talking to a couple of rsx autocross buddies and they seem to think that front tires only is the way to go. maybe do like kenny said and even get smaller tires forthe rear.
I used to play on the track with my stock 05 and know someof what you are talking about and to me cost wise it seems to make sense to only get the fronts as well.. buy two fronts first. if you don't get the desired effect buy two rears..
i think a stiffer front sway bar would give the oppisite results of what your looking for.
Old Mar 19, 2007 | 01:14 PM
CTS-V Import Slayer
That would actually make it worse than it is now.
Old Mar 19, 2007 | 01:16 PM
CTS-V Import Slayer
Talking to a few folks over the weekend too...they say its INSANE to only do the fronts. The net effect, according to them, would be exactly what I was thinking....five fold. The rear end would swing right around and keep going. They recommended going with sticky tires on all four.....wider front rims if possible.
Old Mar 19, 2007 | 03:03 PM
chill_dog's Avatar
I know...someone mentioned "find someone to make a stiffer front sway bar"...was merely stating that one is already made.
Sorry if it came across as implying you should get one.
And yes, wider front tires/wheels will help (like that one Pontiac is stock).
Old Mar 19, 2007 | 04:06 PM
Kennedy's Avatar
OMGWTF4THGENTL
Sounds like the definition of understeer.
I was actually going to suggest that you disconnect the front sway bar for a lap or two and see how it feels.
Old Mar 19, 2007 | 04:26 PM
CTS-V Import Slayer
I'm witch cha bro! Cool...so Pontiac has a stock vehicle set up this way huh...making me feel better about that option already! Will be expensive though. Another set of rims..ect....and whatever I am gonna have to do to put em on. Is anybody running 10" wide rims on this board?
Old Mar 19, 2007 | 04:28 PM
chill_dog's Avatar
I believe only X9 will fit in the front if you don't have a drop, depending on the offset. X10 will only fit in the rear, again, depending on offset.
Old Mar 19, 2007 | 06:44 PM
260 HP's Avatar
Actually I tried 19x9 +45 offset and 245/35 R19 tires while lowered about 2.2" on Tein Basic. No rubbing....
Old Mar 22, 2007 | 11:00 PM
Revolutions's Avatar
8AT > 6MT
if you have grippy tires all the way around, what happens is you get more traction. but what he's telling you is if you get sticky fronts, and slippery rears (such as your yokos) the car will tend to understeer less... that's why it's retarded to go staggered wheels with wider tires in FWD cars because when the rear has more bite, it keeps the rear end from "whipping" around, so it causes more understeer
Old Mar 23, 2007 | 10:51 AM
gdcwatt's Avatar
Before I go suggesting something like moving the battery to the trunk, why don't you ask Stuntman, our very own Kensai Racing Koni Challenge TSX driver. You can find Bill Johnson under the motorsports section on the TSX forum; he introduced himself a couple of months ago, just before he won the Laguna Secca event.
Old Mar 23, 2007 | 07:38 PM
CTS-V Import Slayer
Hmmm...thanks guys!
Aug 15, 2019 12:58 PM
tman570
Jun 11, 2019 07:56 AM
divac
Aug 29, 2018 10:13 AM
Sep 17, 2015 09:01 PM
datadr
Sep 12, 2015 09:12 PM
