handling problem
handling problem
i have a 05 tl 6 speed, steering wheel feels light and loose, felt like it has no pressure holding on to the steering. when going over bumpy roads and grooves, it twitches pretty hard to the left and right, alot of feedback from the wheel to the steering, especially on uneven pavement, it just follows the road imperfection
is this a common problem?
here's some works i have done: suspensions, 6 front lower control arm bushings, 2 rear control arms, tires and rims, alignment, no improvement, if anyone here is having the same issue or might know the solution to this, please help~
Its funny your in NYC too, but i am having the same problem. i did 3 alignments, changed my driver side suspension components. I did rotors and brakes. The handling improved some what. Ever since my car was hit on the driver side it never handled the same. I am thinking bent frame maybe. I took it to the dealer who found no problem.
i did, alignment result came out fine, just the rear right side camber is a lil off, im on a-spec suspension not sure if thats normal but i dont think it affects the handling much, thanks for the help!
Also, when you say the "alignment result came out fine," what were the specs on the toe settings (i.e. OEM or some other standard)?
The likeliest scenarios for the symptoms you described are that the tires went bad or the alignment specs are off. FWIW, it seems like the members with lowered suspensions have had best results with the OEM/stock toe settings.
Tell us about your tires-- size, type, age, mileage, cold tire pressure front and rear. Check for bulging in the tire sidewalls on the front and rear tires.
thanks for the response will, im on yokohama avs es100 tires with aspec rims, tire size r 235/40z r18 95w, it has about 50% thread left, about 20k miles on them, all tires n rims were checked before i put on the car, no bulge dents or damages, using nitrogen air 35lbs front and 32lbs rear.
alignment setting for toes are .02 front and .07 rear which is within factory spec range, rear camber is -1.8 off by .03 (factory spec -1.5) which is the only thing "red" showing on the reciept
i was running on stock tires rims and suspension when i had this problem, i thought it was the rims and tires or suspension causing the bad handling so i went and changed them all, i even changed all front 6 bushings for the front lower control arms and 2 rear control arms, problem still exist.....
Pretty much.1) Swap your front tires with the rear tires, adjust the pressures to 35F/32R and see if there is a difference in how the car feels. If the car feels much different, it's the tires.
2) If there isn't much difference in steering feel, check the suspension mounting points-- see https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/something-scary-happened-today-709114/
G/L!
:ibthreadsmerged:
Deff not the only one....on f'd up roads, my car can not go in a straight line. Its 99% perfect on even surfaced roads, it won't even nudge....but once I get into those grooves on a beat up road, the car has a mind of its own. Then again, I am dropped pretty low and have larger/wider wheels. Its not so bad with the stock wheels...still there though..
2) If there isn't much difference in steering feel, check the suspension mounting points-- see https://acurazine.com/forums/showthread.php?t=709114
G/L!
:ibthreadsmerged:
thanks alot
i totally feel u, how was ur alignment result? did you have any kinda camber kits installed?
by the way, im running on a-spec rims n yokohama avs tires with a-spec suspension, which is made by acura, so i dont think it would mess up my rear right camber spec...so something wrong or its normal?
It wouldn't hurt to make them set the toe at 0.
Tires can do this.
Do you have an aftermarket RSB? It will make the steering feel lighter. It won't make it tramline.
Worn components which I think you're covered.
Rack and pinion is a possiblitiy but not likely.
Did it do this from the first time you ran these tires or did it happen over time? My car with the current tires is twitchy and it's getting worse as they wear. My new ones go on tomorrow so I'll know for sure if it's the tires or not.
Tires can do this.
Tires can do this.
Tires can do this.
I had this issue on a 2002 Nissan Altima. All I did was tighten an adjusting bolt on the Rack and pinion unit. I also had excessive steering wheel movement at 65 mph. tightening the adjuster a little made all the difference.
thanks for the responds, do you know where is the rack and pinion adjusting bolt on this tl? i dont think it is adjustable at all, well....the handling got so much better the first week when i got the new tires on, but now the problem is coming back and its getting worse everyday...i really dont know what else to do with it
tman570
Jun 11, 2019 07:56 AM
MrHeeltoe
79
Oct 14, 2015 08:47 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Sep 17, 2015 09:01 PM
