H-tech and A-spec comparison please!!
I hardly ever start threads. But I just couldn't find enough pics for my visual pleasure. Thought it would help others out in the future as well.
If its been done and I just couldn't find it(trust me, I looked), mods please merge threads.......
I'm really trying to find more pics of people on H techs. I only found like 2, and that was Predatorbird and some other guy with an AM 3G(forget name).
Reason why I ask for Aspec comparison is b/c some people say its same height and I really don't believe it. Plus, it may help out other peeps. So please post pics and/or links of these.....
Thanks everybody!
Thanks everybody!
96SC4 (08-12-2013)
TLX-S
yes, 18s
here is my progress thread
https://acurazine.com/forums/3g-tl-photograph-gallery-96/wilzrsxs-progress-thread-new-ride-857203/
this is a local member who also decided on the H Techs after seeing mines
https://acurazine.com/forums/3g-tl-photograph-gallery-96/hockeyman23s-picture-thread-am-ftw-updated-2-22-15-a-806363/
96SC4 (08-12-2013)
How much lower the H Tech's are is barely noticeably over A Spec, its almost the same drop to the naked eye however the A Spec's will be a bit stiffer and give you noticeably better handling. To debate the drop between H Tech's and A Spec's doesnt make much sense to me because what difference is .2 or .3 of an inch going to make? The real difference in the two is the ride comfort. Always remember, when it comes to suspension the better handling you want the more comfort you have to give up and vice versa.
A-Spec suspension is not low; it's lower (than stock), but not low.
To people on the streets, they can't tell you're "lowered" on A-Spec suspension, but to you, you can tell it's lowered a bit.
The following 3 users liked this post by guitarplayer16:
Also, "to debate the drop between H techs and A specs" not making sense to you, i apologize.. BUT, why would anybody compare any two types of suspension...? The reason these two are comparable is b/c they have similar drops. Same reason people debate S techs and H&R race springs.... Height AND comfort are the things to compare.
But thanks for the input. Appreciated
Yep, the MT A-Spec suspension on an Auto will lower the front ever so slightly more than the rear. Its been said here a hundred times tho, if your just after a drop than the A-Spec suspension isn't going to do much for you.
96SC4 (08-13-2013)
BallinOnAbudget (08-17-2013)
Interesting that Aspec is stiffer than the H. You know this how? You've had or ridden in both? I hope the H is softer...that's what I'm really interested in anyways.
96SC4 (08-13-2013)
08_UA7_Gr33k
02-11-2016 02:17 PM
SinCityTLX
10-07-2015 01:24 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
4drviper
09-23-2015 07:42 PM
