G37s vibration at 60mph
i got the g37 wheels on my car but it has a weird vibration when i do 60mph or higher i heard i need hubcentric rings with the diameter of the wheels or spacers. what ever it it that i need please let me know where can i get it from thanks.
Acura's hub size: 64.1
Infiniti's hub size: 66.1
You will need hub centric rings with an inner diameter of 64.1 & and outer diameter of 66.1. Inner diameter is the back part that will sit against your hub while the outer diameter is the part that will be sitting inside/behind your wheel's hub. This link shows you exactly what you need if you feel the price is too much, check ebay (64.1 to 66.1 hub rings). Good luck.
http://www.justforwheels.com/index.j...cat=hubcentric
MrHeeltoe
20
02-23-2023 01:54 PM
guyvelella
09-30-2015 11:02 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
