Finally Got My 20 X 10 Installed.
B A N N E D
finally got my wheels installed. ill post more piks later. let me know what u guys think. i havnt lowered it cause i need to buy 25 series tires for the rear cause of the offset.
as soon as i get more piks ill post up
That back tire man.... dont knowwww anyway definately looking forward for those better additional pics. I would love to get rid of my 19's to go for this set up.
Congrats and Enjoy
Congrats and Enjoy
B A N N E D
Originally Posted by CL Platano
Can't see nada without a glass..Get bigger pics..
VS#03
Yeah.....there definitely going to rub, the offset I think is either 38mm or 42mm.....they have to be 35mm to use 20x10 setup. FYI.....don't lower it before you know for sure that it's not going to rub.
looks hot!! but i dont think 25 series tires will help you much, looks like the rear tires/rims are sticking out about 1/4" from the fender. like kshawn said, you need a 35 offset in the rear to run 10" wide rims.
1 Post
oh no I ordered some rims and went with 10's in the rear. I dont know what the offset is because the place that I ordered from said that they would figure it out, I hope it will fit when I lower it
what kind of rims are those,how much did they cost you, and where did you buy them from?
I have the same color combo and that looks tight
B A N N E D
if i lower it it will rub as of right now with the fenders rolled it barely touches it has to be a wave in da street for it to rub. if i wanna lower it i would have to go with 25 series tires. Their sevas. and you can find them on ebay. for a bit cheaper than i got them for, but i rather do everyhtign in person and cut the internet shit.
VS#03
Trust me they are going to rub......even if you roll the rear arches. The rim it self is sticking right under the arch and the body of the car. Theres only two options: one get the right offset & two you roll & pull the fenders so they can fit.
B A N N E D
im telling u people it does not rub while its smooth riding, when i hit a bump with 4 peopple in the car it rubs very minimum. it is a 45mm off set. im telling you guys this is my car i know what im telling u it doesnt rub unless im 4 heads deep and hit a really noticible bump.
B A N N E D
Originally Posted by Boartman
JDM,
As far as looks ,it's the coolest setup on this site.
VS#03
JDM,
1 Post
Originally Posted by K-Shawn
Yeah it's a cool setup......but the the coolest I don't no about that. Also we know that's your TL......all we were trying to express if you lower the car, that it will rub. I have the Donz Montanas 20x8.5 fronts & 20x10 in the rear with 35mm offset. The correct and right tire and rim spec is 35mm for 20x10 lowered running 255/30/20 in the rear. You might have to roll or shave the rear arches & if you purchase the Aspec kit you will have to alter the rear part of the kit. I could put quattro peoples in my TL will agressively driving....no rubbing what so over. In the third generation photography section....check out Hot RRP.
JDM96specCTR
10-17-2015 01:06 PM
