Excelerate Performance: Progress 24MM Rear Sway Bar Groupbuy!!
#121
3G TL/2G MDX Owner
ohsix- FSB is a PITA to swap out (must drop subframe to do it). you're better off putting in a suspension to compliment your sway bar. the floaty feeling will be greatly diminished. the stock suspension even in a 6MT is really forgiving and got pretty floaty over speed humps and dips in the road. i know on my set up....no float, and very little body roll. my limiting factor are the tires i'm running (but i knew that when i got them-DWS). i guess it keeps me out of trouble from pushing the car too hard around turns. i still have plenty of going on though.
#124
Former Sponsor
http://store.excelerateperformance.c.../i-225595.aspx
#126
RSB install
The instructions proved are these.
"INSTALLATION INSTRUCTIONS
Progress Technology Anti-Sway Bar
2004> Acura TL Rear
1.Park vehicle on smooth level asphalt or concrete surface. Block front wheels. Jack up rear end of car and support with jack stands.
2. Remove the nuts that hold the end links to the bar . Next, remove the factory bushings and brackets. Remove the bar from the vehicle.
3.Locate the pivot "D" shaped polyurethane bushing and tube of special grease supplied in the hardware kit. Cut the end off the tube and apply grease to the bore of the bushing. Open bushing and snap them over the new sway bar,as positioned on the stock bar. Place the new brackets (supplied) over the bushings. Tighten brackets (using the supplied hardwar) and end links to OEM specifications.
4. THIS IS AN ADJUSTABLE SWAY BAR. THE HOLD TOWARD THE FRONT OF THE VEHICLE IS THE SOFTEST SETTING. CHARACTERISTICS IN HANDLING HAVE BEEN ALTERED, USE EXTREME CAUTION DURING DRIVING.
5. Installation is complete. Check assembly periodically for tightness."
The hardest part for me was getting the endlink nuts off. I sprayed them with BP blaster a week ago then hours before installing, had to continuously use it during this install. You need to use a allen wrench to hold the bot in place during removal. This site helped me visualize this http://www.filtsai.com/accord/sway_bar/index.php. Here are some install pictures. I did not have to remove my wheel. If I decide to go to the stiff setting I will replace my end links at the same time, probably should have done it when I did this project.
This is what your kit should come with.
I'd like some advice on how my brake line looks if anyone sees something wrong with it.
This bracket kept falling down on it's own even with it threaded up a few. I had to remove it a few times to make the bracket fit up evenly.
The bolt closest to the front of the car is not tighten down as far as the other one because it feels like it is rubbing on something,but it is still threaded up alot.
OEM REMOVED
I made a short video removing the old bar and putting the new one in place.
http://youtu.be/4VTqupBM7Zs
2004> Acura TL Rear
OEM REMOVED
#127
I don't have the tools or space but my installer used a locking wrench. I hear alot of folks use allen keys. I hope he didn't ruin anything. Wish i would have done it, looked sooo easssssyyy.
Many thanks to Exelerate for the group deal.
This mod is by far the first and best one yet!!!
I have mine on soft, OEM suspension and it handles like its on rails. I love it!! The car feels tight, i never knew what it meant when folks said it before. The steering wheel is more responsive and a little lighter too! Switching lanes is done with little movement (no boat like feeling). Best of all, the car is a BLAST to drive now. I could only imagine how it would handle if i lower the suspension and put it on track(firm) mode.
Thanks to those who provided their feedback as well, they were pretty much spot on with the descriptions.
#133
Had the RSB installed over the weekend and can't say I really feel much of a difference from the OEM 6MT bar. Body roll is about the same, handling feels about the same, cornering behavior feels about the same. I saw the final result of the install, everything looked correct. I was expecting a more dramatic improvement, at least in body roll, but in retrospect, I was basing my expectations on past experience. My previous car was a Maxima and going from no RSB to an aftermarket RSB made a huge difference. Are these dramatic improvement testimonials primarily for automatic TL owners with hollow RSB bars?
#134
#135
3G TL/2G MDX Owner
lsimmons (12-05-2011)
#136
Installed mine today, went with the stiffer setting. It's not like a night and day difference but it's definitely noticeable. Took a few quicker turns but ni higher speed highway or ramps yet.
marcelft
07-10-2018 07:17 PM
MonkeyTrucker
09-21-2015 07:15 PM
k6biv
09-10-2015 07:37 PM
