Eibach Pro Kit Installed but I hear noise...
I installed the Eibach Pro Kit over the weekend. When I'm driving over a good pump I hear this "clunk" type sound as though metal to metal is touching some where. The sound is not outrages but you can hear it and its annoying. The sound is coming from only the rear struts. All the boots and stops are installed correctly and the clear plastic shielding on the coils are also on. The torque value on the top damper nuts are set to 37 ft-lbs; which is for an A-spec setup. What is the torque for the top damper nuts with the Eibach Pro kit? Do I need to wrap the coils with insulation of some sort?
Originally Posted by Kennedy
Loose swaybar... or your just plain old bottoming out.
DER NEUE ^
first of, are you reusing your stock shocks or using koni shocks, if it's koni, you can't reuse the stock rubber spring isolator so the spring bottom will be seating on bare metal base and that's ok as long as the bottom spring end doesn't touch the wall of the base it is seating on. you suppose to leave about an inch of space between the base wall and the spring end so they don't touch and rub against each other. other than that it could be the washers touching or something, did you install those in correct position?
BerettaBri
I just had an Eibach Pro Kit with Eibach dampers installed in my TL-S over the last few days. When I bought the car, it turns out there were already Eibach sway bars installed in it. I had the same clunky sound in the rear, my mechanic told me the old swaybar linkages were the culprit. Replaced those and it is silent and very tight.
Love that Eibach spring and damper kit... the car feels as if it floats over dips and bumps and I can take turns at 85 mph without any give. Only thing that looks wierd is the back wheel wells appears to be dropped with less gap than the fronts, but I was told that over the next couple of weeks driving it will settle down a little more all around. It is supposed to be a 2.1" drop in the front and a 1.6" drop in the rear.
What do you think this ?
Originally Posted by JD TL-S
Mine actually makes a noise in the front, I hear something strange coming from the
front drivers side ???
I went ans retorqued the nuts/bolts with a load. Also check to make sure that the plastic isolator on the Eibach sspring start from the second coil from the top.
Zonian22
11-14-2015 01:20 PM
nuldabz
09-03-2015 05:49 PM
Zonian22
09-02-2015 08:19 AM
