Drag Radials and Rims
Old 03-08-2008 | 11:00 PM
bent09's Avatar
horny =
Did a search but came up with nothing.
Any recommendations on a drag radials and rims?
The biggest drag radial I seem to find is on a rim 17x8 but I have no idea if they would fit and 06 AT TL.
I think we have to go 17 to clear the stock brakes.
I am just curious to run the 1/4. To me it seems like a waste going knowing I am going to be pissed I could not hook up.
06-TL-SC
Old 03-08-2008 | 11:34 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
what? dude you can run 2 NITTO NT555R's and call it a day
get 2 enkei 17x9 rpf1 offset I believe is 35
Old 03-09-2008 | 02:06 PM
bent09's Avatar
horny =
Would Nitto NT555R's that are 275 fit?
Thanks for the advice.
Old 03-09-2008 | 03:21 PM
ifirahse's Avatar
SlammedOnKonis
On an 8-inch rim? No way.
Old 03-13-2008 | 11:47 AM
bent09's Avatar
horny =
9- inch?
So the set up would be:
17x9 rpf1 35 offset
275/40-17 Nitto NT 555R Drag Tires
Old 03-14-2008 | 03:22 AM
94 DC4 RS LSV/Turbo
Well it depends are you auto or manual... Cuz if you don't have bbk you can fit the 17x9.5....
Old 03-14-2008 | 09:19 PM
RYAN97812's Avatar
8 second & 150 mph member
275 nitto dr fit on the stock wheel, been there done that. I would suggest 245 45 17 nitto dr on whatever 17x8 wheel u choose. I didnt get bad 60 ft with my 245 35 19 nitto 555 with 41 psi in em. 2.01 60 ft just dont have to hammer the throttle through first but as you know im 6spd.
Old 03-14-2008 | 10:26 PM
MWalsh9152's Avatar
all work and no play
2.0's must feel quite impressive compaired to what youre used to huh? LOL
Old 03-15-2008 | 01:58 PM
I hate cars's Avatar
Nitto or BFG drag radial work nice. My old BFG dragradials would hydroplane at 40mph in the rain but I think you're talking about a set dedicated to track only use, right? Just make sure to get a drag radial, there's a huge difference in traction from even the best "regular" tires.
If you're getting a spare set of rims for the track only, you would be better getting a 15x9" rim with something like a 275/50 tire.
You should be able to get a solid 1.8 60' with some practice. I believe one of the few members here who ran his car at the track pulled a 1.9 on regular tires and a lot of practice. Nice to see someone actually taking it to the track.
Old 03-15-2008 | 02:11 PM
94 DC4 RS LSV/Turbo
mmmmh 15x9? wouldn't that be a tad bit toooo low... remember the tl does hang low
Old 03-15-2008 | 02:20 PM
That's the reason for the taller 275/50 or 55 tire. The overall diameter would be about the same. Less weight and possibly more traction with low air pressures.
Old 03-16-2008 | 12:34 AM
94 DC4 RS LSV/Turbo
mmmmh ur right because the motor wouldn't throw the weight to the rear... damn the wheel hop... nonexistent.... I am going to look at this also for a track setup... get some random lightweight wheels run spacers and get them painted black with a red lip to match my rear
Old 03-16-2008 | 11:07 AM
MWalsh9152's Avatar
IF the brakes would clear the 15" rim that would be the best setup, air it way down and then a nice big sidewall to wrinkle damn do I miss racing
Old 03-16-2008 | 11:12 AM
Aman's Avatar
Your Friendly Canadian
don't know much, but I highly doubt you can fit a 15' rim while clearing the brakes. go with lightweight 17 to be safe, or 16.5s if you can find them.
Old 03-16-2008 | 11:42 AM
LOL, forgot about the brakes. I'm used to dealing with a car with 10.5" disks. I wonder if a 16" would clear the Brembos?
Old 03-16-2008 | 11:43 AM
Aman's Avatar
also recognize that spoke design has an affect on whether you can clear the brembos or not.
Old 03-16-2008 | 04:55 PM
anx1300c's Avatar
Lightbulb
Wrinkle is caused by the weight transfer to rear of the car, so I'm not sure how you could wrinkle the fronts.
Old 03-16-2008 | 06:50 PM
Wrinkle is from the tire wrapping up. I've seen FWD cars do it though not nearly like RWD cars do.
Old 03-16-2008 | 08:37 PM
MWalsh9152's Avatar
the tire wrinkles due to biting, the tire grabs, but the rim is now moving a bit faster allowing the tire to retain its traction, if the sidewall is stiffer its not going to have that added advantage that you get from having give in the sidewall, all that weight transfer does is help keep the tires planted by putting extra weight on them.
As for the tire wrapping up, it actually kinda balls up and is refered too as tire shake, I dont have any knowledge of high power FWD cars, but I would imagine that they too can shake the tires
Old 03-17-2008 | 12:40 AM
94 DC4 RS LSV/Turbo
mmmh if you want to run a 15" wheel... spacers would be good... after all it is for track use... so running a spacer would look hot and also functional
Old 03-17-2008 | 07:06 AM
MWalsh9152's Avatar
http://marktg.toyotires.com/file/30029.pdf
Old 03-17-2008 | 09:42 AM
94 DC4 RS LSV/Turbo
oh snap so they make conventional sizes... 245/40-18
Old 04-02-2008 | 03:05 PM
bent09's Avatar
horny =
What about this set up?
Enkei RPF1: 17x9 :: 5x114.3 :: 35mm offset :: Silver
2 NEW 245/45-17 Nitto NT 555R Drag Tires 45R17 R17 45R
Total cost would be around $ 865.00.
Am I crazy?
Old 04-02-2008 | 03:57 PM
MWalsh9152's Avatar
if you want the hook then that should certainly help you get it
another option I just thought of is the Mickey Thompson ET Street radial. Its been a few years since Ive been to any significiant drag radial races, but the last time I did all the heavy hitters were running the different version of the MT ET street
they have a 245/45/18 which would look pretty good on a set of 04 a spec wheels unfortunatly they dont have anything in a reasonable size for the 17" rim
kev87a
11-02-2015 07:40 AM
Gout
11-02-2015 12:22 AM
kev87a
10-18-2015 02:03 AM
dirleton
20
10-16-2015 01:48 PM
Froid
09-27-2015 06:16 PM
Quick Reply: Drag Radials and Rims
