Do i need hub centric rings on my car?
Hey yall
I got me a set of Volk TE37...but do I need hub centric rings for my car?
and what exactly does it do...stop vibration?
Team Nighthawk Member
It eliminates vibrations because the weight on the wheels are now resting on the Hubs in the very center of the wheel INSTEAD of on the outer bolts (that can be ever so slightly off round, or have minor play causing you to feel like your tires are not quite balanced).
cTLgo nailed it: Yes you do
Originally Posted by cTLgo
Yes you do, and it will eliminate any vibration that may be due to the wheels.
AND if you tighten the lug nuts down more than more than the suggested torque specifications then you can damage the wheel....Take advantage of the hub rings for a factory smooth ride. No use putting on performance wheels and tires just to have a vibration introduced when you go over 70mph
Additionally if you think in terms of just "off center" variability (which can be true as well) the net result is that it still screws up the ride, and then you make a STRONGER case for the hub rings.
Ackniculous One
Hub centric rings are a must for any aftermarket wheel that is not an exact center bore fit. The only aftermarket wheels I know of that fit our cars and don't need hub rings are the RonJon wheels sold on this forum board.
I've had 5 sets of aftermarket wheels on various cars I've owned and all of them vibrated pretty bad without the rings. They are extremely cheap and will save you tire wear and annoying vibration on the highway or above 45mph.
AM MT Navi
would these be fine?
ebay-hub centric rings
no case to be made, hub rings are needed if the wheel bore is bigger than hub. i was just quetioning some of the other posts which suggested what they do.
AM MT Navi
Originally Posted by Sniper 55
I dont know they look fine to me but alot of my boys told me to go with rubber ones and i looked it up online and rubber waz rated better then metal
will have to do a little research
