D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
#122
94 DC4 RS LSV/Turbo
99.999% of tsw wheels will not clear the bbk... you might need anywhere from a 5mm to 10mm spacer... no telling what it is... if you go anything above an 8mm spacer you will be forced to roll on 235... I preffer 245...
#123
Questions on Wheels
Wheel Make/Model: SSR GT3
Wheel Size (**X**): 19 x 8.5 Front with 235/35, 19 X 9.5 Rear with 245/35
Wheel Offset (+**): 43
19x8.5 offset 43
19x9.5 offset 43
will these fit on a 2006 Acura TL???
Can i make them fit, with an adapter or something?
Thanks in advance
19x8.5 offset 43
19x9.5 offset 43
Thanks in advance
#125
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/why-you-should-get-255-40-17-tires-your-oem-rims-595122/
#126
'06 NBP TL 6spd
Not sure if search is working yet. But TONS of info in regards to tthis
https://acurazine.com/forums/showthread.php?t=595122
#127
Here a answer i got from my question from another post, regard a little more wheel protection"
245/45/17 will throw you wheel diameter off a little bit if you are going 60, your speedometer will be reading about 59, but it will give you more protection. If you use 245/40/17, it will throw it off to, but it it will be reading slower, so if you are going 60 according to the speedometer, you will be actually traveling at 61.4 MPH.
#128
#129
94 DC4 RS LSV/Turbo
personally either works... I'd suggest to go with whichever is cheapest
or roll on 255/40-17 and call it a day
#130
Its MY Car & I Love It!!!
Will these fit my car?
NBP TL-S 08
KMC Dime 20x8.5
Falken 452 245/35/20 tires< i'm kinda iffy about these...i dont want a thick tire...I think I'll be better off with 235/30/20 since I plan on dropping it about an inch and a half in the near future. What do you guys think? Will this wheel be a problem for my brembos?
Pick of the wheels
NBP TL-S 08
KMC Dime 20x8.5
Pick of the wheels
#131
Making the mighty dollar
I needed to see if these will fit my car... I have a 05' TL with 6 Speed tranny
Wheel Make/Model: VOLK Le37
Wheel Size (**X**): 2 18x7.5 with 225/40/18 tires and 2 18x8.5 with 245/40/18 tires
Wheel Offset (+**): 50 offset
If lowered (amount): 1.3-1.5
#132
94 DC4 RS LSV/Turbo
NBP TL-S 08
KMC Dime 20x8.5
NBP TL-S 08
KMC Dime 20x8.5
no these will not, the le37 are discontinued if you didn't know, so you will actually require high disk clear model... 18x7.5 in front will never clear bbk in a +50 even if it were high disk clear if you added maybe a 20-25mm spacer it would work but then what is the fun in running a 7.5 wheel in such a big car
#134
I have one more set I needed to check and see if these will fit my car... I have a 05' TL with 6 Speed tranny. Thanks again
Wheel Make/Model: AXIS Penta
Wheel Size (**X**): 2 19x8.5 offset +35 with 225/40/19 front and 2 19x9.5 offset +40 with 285/30/19 tires. (I will be getting new tires for the rears if these wont fit)
Wheel Offset (+**): +35 front +40 rear offset
#135
94 DC4 RS LSV/Turbo
get that one and it will require a 5mm spacer to clear... h&r $60 on ebay
#136
94 DC4 RS LSV/Turbo
the front will require a spacer... should be a 5mm
#139
Question on Wheels!
Questions on Wheels
Wheel Make/Model: Work rezax
Wheel Size: 18x9 (F) 18x9.5 (R)
Wheel Offset: +48 (F) +45 (R)
If lowered (amount):1.75" front, 1.5" H&R sport springs /w aspec suspen
Thanks~!
Thanks~!
#140
Will these fit
Questions on Wheels
Wheel Make/Model: Axis Penta
Wheel Size (**X**): 19x8.5
Wheel Offset (+**): 35
If lowered (amount): no drop atm
I tried to order these but the guy at shop said they wouldn't fit very well.
I know I've seen others running this same wheel but wanted a definitive answer. Thx!
#141
Not sure how Al let this slip, but bump this up
Which vehicle?
Which Vehicle?
Questions on Wheels
#143
94 DC4 RS LSV/Turbo
Questions on Wheels
as for them fittin on a TL... they fit all day
#146
new to the import world want to put 20s on a 06 tl, and i don't want to lower it but i want to fill the gap, was looking at Konig Unknown wheels and was just wondering what advise u could offer as as far as offset and all want to keep it as close to factory ride and tire size a possible thanks
#147
#148
94 DC4 RS LSV/Turbo
#149
94 DC4 RS LSV/Turbo
where are you rubbing? you are friggin slammed, I would say yea raise it up slightly so you dont slice into your tires, get a camber kit and lower her right back down
#150
Thanks for the answer on the wheel size. Now what size tire can put on that wheel?, i would like to go just a liitle bit wider then the factory width or would the wider wheel do what i wanted?
#151
Fit?
Will this fit:
Transmission (Manual or Auto): Auto
Year/Trim (04-07, Base or Type S): 2007 Type S
Wheel Make/Model:
Wheel Size (**X**): 18” x 8”
Wheel Offset (+**): 38mm
If lowered (amount): Stock
Want to run: 235/40-18 tires
Wheel Make/Model:
#157
Need your advice ASAP. Found a killer deal on these AME's but idk if they'll work.
Wheel Make/Model: AME Tracer FS01
Wheel Size (**X**): 18x9
Wheel Offset (+**): +25
If lowered (amount): n/a
Vehicle: 2005 Acura TL AT
Is the offset a problem?? But if you think they'll fit, what would be the best tire width? 255?
Thanks a ton. I've been leeching info from AZ for years and its bout time I expressed some gratitude!
#159
iScrape going into
#160
94 DC4 RS LSV/Turbo
I ran 245/40-18 on a 18x9 +25... 1.5" frontal drop, 1.2" rear, no rub infront, rub in back but I didnt have the fenders rolled
front is good, rear will require negative camber, as well as fender rolling, biggest tire you could run is 255, but expect to run into rubbing issues, 245 worked for me
