Continental, dunlop or sumitmoto tires?
I need to replace one of my stock oem TL-S tire. Which should I go with? Continental extreme dws, dunlop sp sport or sumitomo HTR?
My stock michelin tire size is 235/45r/17.
I noticed the tires that i listed above has the letter Z (235/45Zr/17) What does ZR indicate?
I just purchased two new continental extreme contact dws tires. It would only be logical to get two new front tires instead of just replacing one tire. I figured the handling would be off if i was to just replace one front tire while the remaining three are used.
Just drive...
As far as what the ZR means....this explains it very well and came from Tirerack.com:
Speed Rating
Today, the only tires that continue to include the speed rating "in" the tire size (P225/50ZR16) are Z-speed rated tires. In this case, following the two digits used to identify the aspect ratio are the letters ZR to identify the tire's speed rating (Z) and its internal construction (R).
So, in a nutshell....the Z is the speed rating, and the R stands for "Radial" which is the internal construction type.
Registered but harmless
Received 1,149 Likes
The OEM tires-- all-season Pilot MXM4, all-season Turanza EL-42 and the Potenza RE030 or RE050 summer tires-- are all W-rated.
The ungoverned TL tops out @ 155 mph, so V-rated (up to 149 mph) tires are deemed inadequate by Acura. FWIW, the Type-S does have a governor @ 132 mph.
The next step after the V-speed rating is the W-speed rating, which does exceed the top speed of the stock 3G TL.
Received 6,470 Likes
I've had good luck with a new set of Conti's DWS tires so far.
2011 National AcuraZine Meet-Kansas City-June 12, 2011-Details Here!
https://acurazine.com/forums/showthr...745576&page=14
And then read the tirerack survey (DWS ranked as the #1 UHP A/S tire):
http://www.tirerack.com/tires/survey...jsp?type=UHPAS
09-17-2015 09:01 PM
