Comptech vs A-Spec
Comptech vs A-Spec
What one rides better, and lowers the car more, or is it a toss up? My budy has a 03 CLS with comptech springs and he says it rides nice, and is fairly low. Anyone know how low the CT springs will drop a 05 TL? Thanks! Just wanted some feedback between the two.
IMO, the Aspec suspension will ride closer to OEM vs the Comptech. The CT will drop the front about 2.1" and the rear 1.5". Aspec about a subtle 1". BTW, new version of the CT is the same spring as Eibach pro-kit. Here's a link Lowering Options for some other info on springs.
The A-Spec only drops you less than an inch. When first installed, I measured a .5" drop. I did not measure again after the springs settled, but it could not have lowered itself dramatically after that.
I got the A-Spec because it was a matched spring & shock option.
Do the Comptech Springs w/ Koni Yellows ride A LOT harsher than the Aspec suspension. Im tossing and turning between these two set ups. From what i know from reading is that the aspec suspension gives you a minimal drop but is more forgiving on the bumpy roads but my question is is the comptech set up that harsh on bumpy roads?
If you're getting anything from the dealer it's an Acura part (meaning a-spec) or nothing at all. You can always buy aftermarket (Comptech) parts of course and pay them to install for you, if it's a leased car you'll need to think about putting the original parts back on the car though before you tradein your lease.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
4drviper
Sep 23, 2015 07:42 PM
