car pulls left and right
Old Apr 3, 2007 | 03:15 PM
BukvaMan's Avatar
HI. I have ronjon 19" wheels with toyo 245's PX4 tires, not to long ago i hit a pothole bent one of them and had it fixed and an alignment done....ever since i did that for some reason i started to notice the car pulling left and right depends wich way the raod leans to. Obvioulsy that would make sense but in my case since i have wide low profile tires its very noticeble and it really sucks driving like that.....the steering also feels very heavy especially when you notice the car pulling to one side and trying to bring it back, it kinda takes an effort.
Is that normal >>?? how are you guys feeling about it do u experince the same thing with the similar setup.... i drive a lot around NYC and the roads here cant be worse thent they are so it really bothers me.
Old Apr 4, 2007 | 10:10 AM
mishar's Avatar
Big wheels, especially with high performance tires, tend to pool “uphill”. Power steering is essential there to make driving effortless. It could be that something is wrong with your power steering. Get it checked.
Old Apr 4, 2007 | 06:46 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
Its probably road crown, the crown in the road is causing your tires to pull which ever way the road leans, your tires may also be following the contours of the road!
Old Apr 4, 2007 | 10:09 PM
Will Y.'s Avatar
Registered but harmless
HI. I have ronjon 19" wheels with toyo 245's PX4 tires.....the steering also feels very heavy especially when you notice the car pulling to one side and trying to bring it back, it kinda takes an effort.
What tire pressure are you running? 36- to 40-psi (while cold) in the front tires may partly solve your problems.
The alignment shop may have lowered your tire pressures to 32 or something too low for your tire/rim combo before doing the alignment; this would cause more sluggish response and require greater effort for steering corrections.
Old Apr 5, 2007 | 02:28 PM
BukvaMan's Avatar
well the car was pulling more to the right before i took it to acura, they rotated the tires and performed an alignment on the car. So the car now pulls both ways depending on the shape of the road of course. I guess i didnt feel it before since it was pulling to one side much more. I put all of them to 36 PSI. My problem is that it seems so hard to center it, everytime i feel it pullin when i wanna return it a little bit u can tell its fighting u a little wich really is uncomfortable. I dont remember the car doing that.
and also in warmer temperatures its less noticeable since its easier to steer.
Old Apr 5, 2007 | 02:41 PM
Will Y.'s Avatar
Try increasing front tire pressures to 39 psi (cold) while keeping the rears at 36. Let us know how that feels.
Old Apr 6, 2007 | 06:22 PM
BukvaMan's Avatar
I just did that thing what u said and it made a huge difference. I couldnt belive that by just doing that it would change the whole thing how i feel about that car driving , its still there but i guess whatever is left its just wide tires but it doesnt really pull as much at all.
thanx buddy
Old Apr 6, 2007 | 11:05 PM
Jesstzn's Avatar
Toe out will make it hunt like that .. have the alignment rechecked.
Old Apr 10, 2007 | 12:31 PM
TLRIDA's Avatar
I had the same problem and all it took was an alignment to fix it. sometimes its simple things.
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
