Can anyone explain the difference between a chamber and camber kit is?
Old 10-28-2013 | 08:38 PM
Phinney's Avatar
Question Can anyone explain the difference between a chamber and camber kit is?
What is the difference between a chamber kit and a camber kit? If there is a previous thread already created on this topic, a link would be appreciated.
Old 10-28-2013 | 09:00 PM
usdmJON's Avatar
Difference?
Camber kit = lets you adjust camber
Chamber kit = nothing to do with cars
Hope that helped!
mannytonio (10-30-2013)
Old 10-28-2013 | 09:28 PM
Phinney's Avatar
Originally Posted by usdmJON
Difference?
Hope that helped!
Haha thanks, (yes i am a noob and don't know very much about modding my own car) but what is a camber kit?
Old 10-28-2013 | 10:02 PM
pohljm's Avatar
stock suspension geometry when lowered will naturally camber. wheels look like this //-\\. a camber kit will allow you to make the wheels look like this ||-|| again. it corrects suspension geometry. some people use them to make car //-\\ because they like it
The following 7 users liked this post by pohljm:
Doh21061 (11-15-2013), ebelp (10-29-2013), justnspace (10-28-2013), mannytonio (10-30-2013), paperboy42190 (11-14-2013), Predatorbird (10-29-2013), thoiboi (10-29-2013) and 2 others liked this post. (Show less...)
Old 10-28-2013 | 10:06 PM
^best answer
Old 10-29-2013 | 09:23 AM
ebelp's Avatar
2014 Jeep SRT
Some negative camber:
Some negative chamber:
The following 7 users liked this post by ebelp:
abpmerg (11-16-2013), Doh21061 (11-15-2013), justnspace (10-29-2013), nttstt444 (10-29-2013), paperboy42190 (11-14-2013), thoiboi (10-29-2013), Will Y. (10-29-2013) and 2 others liked this post. (Show less...)
Old 10-29-2013 | 10:48 AM
usdmJON's Avatar
Oh my bad.
Like the guy under me said but with less bias.
Camber kit lets you adjust camber; which is the tilt of your wheel from top to bottom.
When aligning your wheels side to side adjustments are toe, top to bottom is camber.
Old 11-14-2013 | 08:09 PM
Phinney's Avatar
I like the look of that Type-S, what do i need to do to to get that look? Do i need to install coilovers and then buy a chamber kit to get that poke, or get wider tires in the back?
Old 11-14-2013 | 08:35 PM
paperboy42190's Avatar
Here's a chamber for you:
Old 11-15-2013 | 02:17 PM
OTT3R's Avatar
:gheywave:
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
o8 ENVII 8o
11-30-2015 04:23 PM
09-17-2015 10:16 AM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Can anyone explain the difference between a chamber and camber kit is?
