can anyone comment on H&R wheel spacers
CTS-V Import Slayer
Originally Posted by baysic tl
this might be a dumb question but what is the need for the wheel spacer? not really sure and wouldn't you just buy a wider rim?
Originally Posted by adonis_xu
Spacer can possibly cause viberation while the vehicle is high speed, is that ture?
not vtech... VTEC!!!
I used to run 10mm H&R hubcentric spacers b/c I want the Audi A8 rims on my A4. The bolt pattern was correct but the offset was off.
Running a set of 10mm change the offset of the rims to 38mm, which is close enough for the A4.
I ran that setup for a good 3+ years and never had a vibration issue. I even took my car to a track event and an autocross.
You might need longer stud, for the audi it was pretty easy as we have wheel bolts instead of lug nuts. And also make sure you torque the wheel down with a torque wrench.
I got my spacers and bolts from ecs tuning - pretty popular place for the Audi crowd. I'd say call them.
IDontRideFastIJustFlyLow
i want to put my rj inspyres on from my wifes honda accord 03 to my TL 04 , now the inspyres are 18 x 7.5 and the stock tl rims are 17 x 8 . i wanted to swap them out first when i sold my 02TL which the inspyres were on but was told they wont look good since my 04TL is width is 8'. so im wondering whether to put 5mm spacers or not with the +ve and -ve points mention here and if so which one to get and what other accessories reqd along with this
Anything more then 3mm really requires h&r or something just like it, hubcentric spacers. Last i checked they were like $50 a piece and you need longer studs and need to install it.
Here is an example of pricing http://www.namotorsports.net/listing...97/startrow/11
but i'm sure you can find others and maybe lower prices.
jmoney2001
09-11-2015 12:07 PM
mtl_ilx
09-03-2015 09:48 AM
