CAMBER KIT-help needed
Hi everyone. I have 07 TL-s with Eibach springs 1.2" front and back. I want to put a camber kit and not sure what is a good product for the money. HTspec from Heeltoe is $609 for front and back. Any recommendations would be appreciated.
Former Sponsor
Are you only looking for a rear kit? We have great pricing on the SPC kit for the rear that adjusts -2 to +4.
SPC EZ Arm XR - Excelerate Performance - Japanese and European Performance Specialists!!
The Ingalls adjusts camber and toe which is great, though we've seen some bad experiences with the bushings on here so I don't typically recommend them. Most kits we've installed locally have been fine and we do have them in stock.
Ingalls Alignment Kit - Excelerate Performance - Japanese and European Performance Specialists!!
Slpr04UA6 (11-20-2015)
You don't need a camber kit for a 1.2" drop.
What you need is to make sure your toe is set properly and that can be done with the stock suspension.
I agree, in general, but I've seen some pretty bad negative camber from worn out struts, and we all know that lowering springs kill stock struts. I think an alignment is in order to make a true decision on it. Also, I don't *need* a camber kit for my car, but dialing out some of the negative camber in the rear will make the wheel/tire combo more flush.
MikeTC
11-02-2015 01:52 PM
Hardhotel352
88
10-24-2015 09:44 AM
