Buying new brake rotors
Old 06-11-2009, 01:08 AM
johnny911's Avatar
Should i buy Rotora Brake Rotors - Drilled & Slotted or just Slotted? Will drilled & slotted rotor crack?
Old 06-11-2009, 01:17 AM
johnny911's Avatar
Also what brake pads should i buy? Duralast gold?
Old 06-11-2009, 01:26 AM
johnny911's Avatar
How about - ROTORA H2 Ceramic?
Old 06-11-2009, 01:27 AM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Buy only slotted rotors, not drilled/slotted. Also, if you're going with Rotora rotors, buy Rotora pads.
Old 08-19-2010, 12:42 PM
97mx5's Avatar
Personally, I prefer the look of drilled only -- but the slots do help the pads clean and extend rotor life
Old 08-19-2010, 01:06 PM
VQPower37's Avatar
slotted is a good idea for street use ... but drilled and slotted looks better IMO, i would go for the drilled and slotted just for the looks if i were you
Old 08-19-2010, 01:44 PM
dajonx's Avatar
Can you please explain why only slotted? I thought I read somewhere in the forum that drilled/slotted is as good (if not better) because it lowers the rotor temperatures during braking.
Old 08-19-2010, 01:54 PM
97mx5's Avatar
A lot of people feel that drilled rotors crack -- with that said, cheap blanks, drilled with no champering are more likely to crack. A good blank, drilled and machined properly is not likely to crack. Secondly, unless you are tracking your car, or autocrossing, it is highly unlikely you would be able to heat up the rotors enough to do any damage to cheap rotors. I have run cross drilled/slotted rotors on my last 3 cars -- supercharged Miata, 350 Z, and 330 CI with absolutely no issues.
Old 08-20-2010, 06:46 AM
dajonx's Avatar
Thanks for the info!
In slotted rotors, will rusting occur in the slots? If so, is that ok?
Old 08-20-2010, 11:10 AM
I hate cars's Avatar
Received 1,812 Likes on 1,283 Posts
Rotora drilled and slotted will work fine. They're a high quality rotor and will have no cracking issues. I'm running their 13" drilled and slotted rotors with no issues.
Old 08-20-2010, 11:14 AM
sixsixfour's Avatar
rust will always occur on cast iron or steel rotors and thats just fine. by the time the rust eats its way through, you've gotten rid of the rotors by then.
Old 08-20-2010, 12:47 PM
dajonx's Avatar
Thanks for the info!!
yesSIR-S
05-13-2016 05:42 PM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
asahrts
09-04-2015 05:55 PM
Quick Reply: Buying new brake rotors
