Brakes sticks after pad and rotor swap
When you say the caliper piston moves in easily, is this just after the problem or after the car sits, and also do you undo the bleeder at all when pushing the piston inward?
Make certain the caliper is set properly and not cocked and the pins are clean and equal on both sides.
Back to checking caliper sliders and maybe you can view the caliper movement while someone presses on the brake pedal, especially when pushing the piston back out.
Also, if you used after market pads, many folks have had issues with A/M pads being too thick...
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
xsilverhawkx
09-28-2015 06:51 PM
