Brake pads
I put Hawk ceramics on my AT two weeks ago - they feel a little more linear than the OEM pads. There doesn't seem to be as much brake dust, which is supposed to be a trait of these pads.
Iro Ridg .308
Originally Posted by gotjesus
AT
thanks
thanks
Haven't had any issues with the Hawk ceramics. A little more expensive but worth it.
Mine haven't squeeked yet, although I have heard many complaints. I have seen advice that you should use an anit-squeek product on the back of the brake pads (comes in a pink bottle). I bought a bottle when I did my brakes, but when I read the directions, it said it was only for non-shimmed pads. The AT pads are shimmed, so I just used brake grease. I wonder if some of the people who have had problems with squeeking have used the "pink stuff" on their shimmed pads.
Registered Member
Originally Posted by jmbnova
Nope.. I used some of that "Disk Brake Quiet" stuff (red colored) and I haven't had any troubles.....
Did you use the stock stainless shims from the OEM pads? I didn't.. maybe I should install them to see if they reduce or eliminate the reverse squeaking.
As for dusting, I estimate that the Rotex pads reduce front wheel dusting by 80 to 90% over the stock pads.
Originally Posted by Hugh9269
What is the estimate for having brakes done at the Acura dealership? for the 6MT Brembro's? Getting close to needing them..
I was just at the dealership. Said that set of pads (special series from Brembo) were about $180 and they reccomended getting rotors turned at that time to preserve the life of rotors and resist premature warping. Total job would be $340 (he quoted me).
I know that I can pull rotors off myself to get machined at autoparts store for about $40 each. Seems worth it to me to get my hands dirty.
08_UA7_Gr33k
02-11-2016 02:17 PM
