Bolt Pattern? **
Bolt Pattern? **
So I know we are:
114.3mm X 5 Lug
Also known as
4.5" X 5 Lug
I've seen 115mm X 5 -- is that the same, just rounded up and "nicknamed" to make things easier or is it genuinely 115 and different??
114.3mm X 5 Lug
Also known as
4.5" X 5 Lug
Sticky Rice OwnZ joO
1 Post
It's not the same..
I know the 115 bolt pattern is used alot by GM on the American Cars..
Maybe it would help to explain what the 115 vs 114.3 really means..
On a 5-bolt wheel, it's the distance from the center of the bolt to the opposite ring on that runs throught the center of the other bolts..
Here is a pic.. the blue is our pcd of 114.3mm, the purple is 115mm
the red is the bolt holes, and the distance from the center of the hole to the other side is the PCD..
I understand what bolt pattern is....
I just didn't know if saying "115" was a shortened version of 114.3 for simplicity.
I know 114.3 is also known as 4.5
Apparently there actually is a 115...
I'm assuming that won't fit right?
thanks
or will that 0.7mm really matter?
thanks
1 Post
The latest Gen Prelude wheels fits our cars just fine..
In fact, most Honda wheels can be swapped between the various models.
they probably used 115 thinking it's the same...
I think the .7mm won't make that much a diff
it's only .027 inches wider.. so I think it should fit no problem..
It's the middle of the bolt.
neuronbob
23
07-16-2019 10:48 AM
