The best place to put two new tires?
I never got around to rotating my tires so now the fronts are wearing pretty thin. After what I've read online I thought it was common knowledge that new tires should always go on the rear, but when I called a local Acura dealer to see about getting the B service done and a couple tires mounted, the service woman said new tires should always go on the front. So I called another Acura dealer and they said the same thing.
Then I called a couple tire dealers, and one said new tires should always go on the rear, while the other said that if the car is front wheel drive and I'm doing a lot of city driving then it's best to put new tires on the front. That's three sources I've called that said putting new tires in the front can be best, while the vast majority of online advice I've found says putting new tires on the rear is always best and a few sources have even said it's mandatory by law in some states.
Why all the conflicting advice?
Registered but harmless
Received 1,106 Likes
It's a question of where to best avoid losing traction.
Tire Rack says new tires go to the rear, regardless: http://www.tirerack.com/tires/tirete....jsp?techid=52 .
Understeer is easier to correct than oversteer. To avoid losing traction and going into oversteer, better tires go on the rear, regardless of whether the vehicle is FWD or RWD (or AWD).
I'd say wherever the drive wheels are. If RWD you'll have the grip / traction when applying power and you'll also prevent oversteer a little better- yes understeer is more manageable for the average driver, and if FWD you'll have the fresh rubber where the demands of a FWD car are highest- up front. Even if the rear came around on your FWD, you have brand new tires up front. Aim the wheel, hit the gas. AWD I'd lean toward new ones in the rear. But hey, it's just an opinion.
I guess no one does any research any more??
The tires with the best tread should always go on the rear regardless of drive axle/s....
TacoBello (07-22-2015)
Here, let me help.
Hydroplaning. Specifically oversteer caused by hydroplaning.
Installing the new tires on the rear keeps the car in an understeering condition during hydroplaning, which is safer than an oversteering condition.
However, I'm just fine with hydroplane oversteer, which is a near impossibility.
You do it your way, I'll do it mine. In this case, it's personal preference that would dictate where I install tires, not research.
For safety new in the rear, for best wear new in the front... that's why you're getting conflicting advice. Ideally all 4 tires are purchased at the same time so you rotate to keep them somewhat equal. In your case, I would start in the front to give them an opportunity to wear down to match the rears (since summer and no snow/bad driving conditions yet), then rotate. Otherwise, you'll always be replacing 2 at a time. My two cents.
The following 2 users liked this post by ds03:
NBP04TL4ME (07-23-2015),
VisualEchos (07-22-2015)
Always to the front in a FWD car. First, most of the braking force is applied to the front wheels. Second, when you corner while it's wet, you want all your grip in front, if your front tires are slick and the back are brand new, you'll lose traction in the front a instead of turning you'll go straight. If your front tires are new and the back are slick, the back might or might not lose traction, but they usually just follow. Third, your engine is in front and so is 75% of the cars weight. It would be only logical physics that you want to apply the most traction where the most force is applied.
We recommend putting new tires on the rear for safety. Why do companies focus on safety rather than other factors like wear? Liability. Companies would much rather deal with customers who maybe weren't pleased with their tire's longevity than a lawsuit associated with injury or death resulting from incorrectly advising a customer on axle recommendation. I have this question and argument every single day, some choose to listen, some don't. Ultimately it is the individual's decision but I prefer my customers have the safest recommendation as I do not personally want an injury or death on my conscience due to incorrect advice. Not questioning anyone else's reasoning for installing them on the front, there are many understandable points.
The following 2 users liked this post by sonny@tirerack:
350 (07-30-2015),
Oh Sickest TL (07-29-2015)
The thing is, if 1 person in 1000 has an issue, the company is going to err on the side of caution because they remember the cost of the lawsuit. People need to take that into consideration. In this case, no on this board has probably ever had a problem, and likely has never even HEARD of a person that did, but the recommendation stands.
I really can't say, personally, I only buy sets of 4.
My first ricer
I'll agree with rear, better to lose traction in the front than to have the rear swing out when it's wet/snow etc. Personally for a daily driver I always go with 4 new tires, I'd recommend rotating more often.
if what you want to know what is the safest place to place 2 new tires, its always going to be the rear... just like everyone else has said, understeer is easier to control than oversteer for the majority of the average driver on the road
i guess if you were going to a drag strip than placing the new tires on the front would make complete sense
In the past I've quoted Tire Rack's statement that new should go on the rear, however, personally, I put them on the front.
Ever go into a curve in inclement weather driving a heavy FWD vehicle with worn/bald tires on the front? If it doesn't turn, one doesn't need to worry about the back coming around.
Many years ago I was into the little Ford Fiesta (circa 1980) and I don't care what tires were on the rear, it would come around. Even with new, wider 50 series tires on all corners, with a weight of 1600 lbs and only 500 lbs on the rear it didn't take much for the rear to come around at the most unexpected time.
Just my take.
Just my take.
Registered Bunny
Just my take.
Just my take.
I don't disagree with your statement regarding making sure you have traction in the front, but definitely have a problem with anyone who puts themselves and mostly others at risks by being reckless and driving with bald tires.
Then again, you and I both know you shouldn't drive in inclement weather with very worn/bald tires.
I don't disagree with your statement regarding making sure you have traction in the front, but definitely have a problem with anyone who puts themselves and mostly others at risks by being reckless and driving with bald tires.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
In fact, I've had new tires that would hydroplane, poor tread design, lift the front tires right up off the surface at @ 40/50 mph.
cammy5
09-04-2015 11:26 PM
