Best Drop for 3 gen TL
Hey everyone!! i need to drop my car can someone lead me to a good set of lowering springs and wherei can get them for a good price??? i got a A-SPEC lip all around and i wanna drop my car on the stock rims for now. i was told to go with eibach!
and im all about handling !!
thanks guys
thanks guys
Best Drop for 3rd gen TL
thanks guys
thanks guys
AZ Community Team
Received 7,771 Likes
IMO, the "best" drop is 1" - 1.5". The stock gap on my 2007 TL-S is ~2" to 2.25". I say best based on looks and functionality. I think the "best" drop is a little like the "best" wheels - everybody has a different objective and a different opinion.
The Eibach Pro-Kit drop is advertised at 1". H&R Sport Springs are 1.4" Front / 1.3" Rear. I think Comptech are about 1". Most everything else I found is greater than 1.5".
In any case there is a risk of premature shock wear - the more the drop the greater the risk. Most will recommend a shock/spring combination; Koni Yellow are popular. So are Coil-Over's (Tein or H&R usually).
Check the forum vendors - Excelerate; AcuraTLParts and Mr. Heel Toe for prices. Based on the shopping I've done they are competitive.
Quickest, best value way to improve handling is to upgrade the Rear Sway Bar - Progressive (24mm) or Comptech (22mm, I *think*). It's cheaper than springs too.
I've got the Progress RSB with Energy Suspension greasable bushings on the way. Planning to order H&R Springs either this week or next. That means my comments are based on the reading I've done, not personal experience.
GL.
GL.
94 DC4 RS LSV/Turbo
A lot of guys are running tein ss coilovers, others tein basic coilovers, some others are running h&r coilovers, a good majority is running stock or aspec shocks on upgraded springs
Me I would say the best drop is with the koni yellows + eibach/comptech/h&r springs
Height and damper adjustible
Moved to suspension forum, deleted your other thread, and merged with the thread you already started in the suspension forum.
AZ Community Team
Originally Posted by BrianC636
The SP3 Koni's have adjustable spring pearches. Not quite as fine tuned as a coil over but I think they have 5 adjustments on them. Stock ,+/- 0.3, and +/- 0.6
The "regular" Koni's are adjustable as well. 3 positions instead of the 5 with the SP3.
IIRC, the "regular" Koni is up to a 20mm adjustment.
AZ Community Team
Eibach Pro-Kit
H&R Sport and H&R Race
Comptech
Tein S-Tech & Tein H-Tech
Nuespeed
Skunk2
Probably others.
Comptech
Nuespeed
Skunk2
Probably others.
emailnatec
29
09-28-2018 04:27 PM
us285126
10-02-2015 02:03 PM
RSpyder
09-30-2015 12:46 AM
4drviper
09-23-2015 07:42 PM
