ASPEC Suspension Question
I have the Ron Jon body kit on order and I just put 19" inspyres on my 04 TL.
Check out this thread for pics. https://acurazine.com/forums/showthread.php?t=114192
I want a small drop for look and overall handling improvement, so instead of springs I am thinking about going with the Aspec suspension.
So onto my question...
Which should I do first, install the body kit from Ron Jon when it gets here or install the Aspec suspension.
Will the suspension be harder to install once the body kit is on or vice versa or does it really matter?
Im not really auto-inclined so everything will be professionally installed by my local acura dealership and hopefully the body shop that is developing the kit for Ron, since the are here in the So Cal area.
Any input is greatly appreciated.
The A-spec install will be no more difficult/easy once the bodykit is installed... however, you may want to install it first to avoid scuffing your new bodykit w/ a floor jack while propping up the car (I'm assuming you're gunna install the 'spec kit yourself).
If you have the Acura dealer install the suspension, then it totally doesn't matter which is installed first: bodykit or springs.
MrHeeltoe
79
10-14-2015 09:47 AM
