Aspec 18x7.5 50 offset, how to fit with brembos?
Must be TSX A-Specs since the RSX A-Specs were 17x7.5.
Jesstzn is correct, a +50 will be more sunk in than a +45, so a larger spacer will be required. The exact size is something I don't know though.
Thought they were +55, but if hitting or too close, need @ 3mm clearance between caliper and wheel, place washers over the studs until the 3mm caliper clearance is obtained. The total thickness of the washers would equate to the spacer width needed, but if more than 5mm then a spacer with studs would be needed, or longer studs.
Actually to keep the outer part of the wheel in the same location as the stock wheels, you'd need a 11mm spacer if +50, 16mm if +55, so maybe this may be the way to go.
I have these wheels on my second gen tl they are 18x7.5 +55 offset. I saw another member had him on his six speed and he had to run a 15mm spacer in the front and he ran a 20mm spacer in the rear
jmoney2001
09-11-2015 12:07 PM
