anyone doing spacers with their aspec wheels?
Ive got an 04 5AT A-Spec and I think the only thing the TLs need is their wheels to be flush with the wheel wells.
Is anyone doing spacers with their A-Spec wheels? If so, what size are you running?
"Spacers" will ruin your suspension geometry and promote premature wheel bearing failure." They could also result in the tire contacting (and ruining) the fenders.
Summarily, it's a very bad idea.
not sure why you wrote spacers in quotes like its a fake word, but hubcentric wheel spacers are sold by a lot of companies. So im wondering why they would sell them if they cause all these bad problems you speak of.
I know they could result in the tire contacting the fender. I obviously wouldnt push it that far, but I want to push them out so they are very close to flush with the fender. I guess I cant see the wheel being pushed out 10 or so mm would ruin my suspension...
06 TL 6spd. Navi/A-spec
Originally Posted by stillhere153
why not get the RL A-Spec rims their offsets wider no?
ok cool. im lookin into some newer wheels. thanks for the advice everybody. from what i read and saw an 8.5 wide wheel with a +35offset seems to look minty.
Former Sponsor
Originally Posted by mishar
You are right. It won’t ruin your suspension and bring the end of the world. It would just spoil suspension geometry and make your car handle worst. It would look better, but only from side, because from the front and rear your tires would look narrower and too far apart. If you want better look from all around combined with better handling, braking and acceleration you should go for 17x9 45 offset lightweight rims and 265/40x17 high performance tires. It is definitely more money than spacers, but than it is real improvement.
BTW, don't give the OEM engineers too much credit, alot of car parts are carried over between models, the Accord, the 2G TL, CL, Prelude and TSX all have the same wheel offset with widths from 6" wide to 8" wide on completely different suspension.
Then some cars like the TL have a 45mm offset with similar suspension to the accord chasis.
Originally Posted by rondog
I'm sorry, but that is not true, the car will handle and corner with better ability with the wider trackthat is simple physics, there are alot of circuit racing vehicles that use spacers to gain a wider track.
Well, that would be a little bit too simple physics. It is true that wider track makes car more stable, but difference is just a few percents. On the other hand suspension geometry is changed way more and that annuls that little gain, making handling worse all together.
I agree that engineers can make mistake. One of them is all wheel steering concept that sneaked into TL’s rear suspension eating rear tires under load, but you can’t judge that based on carried over parts and different rims width. They use same parts on different models, but they build rest of suspension around them. It is very difficult to measure suspension geometry and that would be just first step in order to say if design is good, so we have to thrust them, just as we thrust them with the rest of design.
Down for a photoshoot?
sorry to ruin your plan to be the first haha
https://acurazine.com/forums/3g-tl-photograph-gallery-96/%5Bib18c1-crzygosu87-%3D-ua6%5D-%5Bjjashaa-scotterson-%3D-new-car%5D-rc-car-%3D-photoshoot-759372/
but its OK, I'll be taking mine off soon for a different set of wheels hahaa
https://acurazine.com/forums/showthread.php?t=759372
Great!....how thick are ur spacers??
2016 E350 Sport
This is not true for small hubcentric spacers. I do not think the OP is talking about using a 1-1.5" spacer.
2016 E350 Sport
I'm using Ichiba 5mm hubcentric spacers in the rear with 18" x 8" A-Spec wheels all around. I think it helped close some of the gap for the rear fender. Also note that the rear tire actually comes close to the fender since there is about 0.5 - 0.75" of metal that gets rolled for those who like that "hella flush" stuff. The ride is perfect and you do not have to upgrade to longer studs. I would not run any spacer wider than 5mm without upgrading the studs. Safety first!
jmoney2001
09-11-2015 12:07 PM
mtl_ilx
09-03-2015 09:48 AM
