Alignment specs
stvtec (08-19-2013)
Just an FYI-The local Acura dealer has the front toe range -.15/+.15 degrees and tries to use +.05 degrees as the set point and also 0/+.30 degrees for the rear, no negative.
happyboy (08-21-2013)
I thought for front-wheel drive vehicles, some negative toe out is preferred due to forward movement of the suspension arms against their bushings as the front axle being "pulled." The opposite is true for rear-wheel drive vehicles.
emailnatec
29
09-28-2018 04:27 PM
4drviper
09-23-2015 07:42 PM
