Alignment - Caster out of spec
Anyone know how the caster could have changed to +6.6 degrees on both front wheels, a difference of 2.6 degrees from the time I installed the A-Spec and now? We had a storm that dropped about 12" of snow on the ground. Everyone and their moms installed chains and turned the packed snow into icy choppy terrain. The bumps were about 1-2 inches in height. I drove maybe 1-2 miles at15mph through this. Could this have bent something enough to affect caster putting it out of spec? Also, if I did bend something, how did it bend so evenly making both sides 6.6 degrees. Firestone said nothing when I picked it up so they're not concerned.
I'm guessing it might be aligner error. Anyone have any ideas? +6.6 degrees is good for straight line stability though I guess...
Yesterday's alignment specs:
Old Alignment Specs done after A-Spec Suspension install 2 months ago:
caster is an imaginary vertical line from the ground thru the center of the hub and up to infinity
the angle is referanced to that imaginary line
Pretty strange for it to be off like that at all, if it is something has usually bent,
I would have the shop double check it, look for DAMAGE, and their machines self testing done. Your a regular--- who isnt looking for a free alignment- just confirmation everything is good to go
They cant sell you a part to adjust caster, so they dont say anything!!
If the Camber too far neg, they can fix that!!
toe- made to do on any TL front/rear
I'll have the alignment done again in a few months. I'm pretty sure they did not measure it correctly. Had it been 3 degrees on one side and 6.6 on another. The roads I went through we no worse than an choppy dirt road. There were no potholes or anything. Just very bumpy terrain for any stiff suspension. I've had the suspension on for 2 months. I'm sure the icy bumpy roads help break them in. So far, the height is perfect for me:
My roommate had his IS250 AWD aligned today at the same shop. The printout looks different like it was done on a different machine or they got a new machine altogether. Can anyone answer this question? Here's the printout:
My roommate had his IS250 AWD aligned today at the same shop. The printout looks different like it was done on a different machine. Can anyone tell me if this is different machine?
Nevermind. I answered my own question. Scheduled an appointment for tomorrow to have the steering wheel centered as the last 2 alignments have caused my steering wheel to be 5 degrees to the right while driving straight as they didn't make sure to straighten the wheel before adjusting the toes.
The technician told me the caster is okay and that their machine has been a little glitchy lately and has been giving strange caster readings when he swings it which goes back to machine error and not my car having issues.
emailnatec
29
09-28-2018 04:27 PM
4drviper
09-23-2015 07:42 PM
