Alignment?
it depends on how long and how much you drive.
if you drive a lot and your tires are wearing and you're not going to be putting on the springs for at least several weeks, I'd get an alignment done ASAP.
but if you're doing the springs this weekend, and no abnormal tire wear, then i'd get an alignment after i got the springs on.
either way, you will have to do an alignment once you drop it.
so the question is, do you have money to do an alignment twice? or do you have enough to spend on 4 new tires? (if abnormal wear occurs.)
do you need an alignment right now for some reason?
if not, wait until you lower the car and then go to firestone and get the lifetime alignment deal for $150. get as many alignments as you want, whenever you want.
keep an eye on your tires.
if there is any uneven wear, get an alignment ASAP.
the TL is very finicky with alignment specs. if its out by a little bit, you'll get uneven tire wear.
with that being said, if your tires are fine...get the alignment done after your springs...when are you getting the springs done?
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
Zonian22
Nov 14, 2015 01:20 PM
ummm I just got back from Florida and they came in to one of the local performance shops I just got to go pick them up and get em on lol
