Acura and Mercedes-Benz bolt pattern...
So I have someone with an old CLK class with 20x8.5 front and 20x10 rear with 40 offset but he claims that the rims are 5x114.3 and he is 100% sure. How is this possible? I thought M-Benz's were 5x120? Are they the same thing? Somehow he put them on his ride and said they were off by approx 1mm.. He took off the wheel and looked behind it and all it said was the wheel width and offset but he's 100% sure that they're 5x114.3. I'm just thrown off by the fact that they fit on his CLK.
Any suggestions?
Any suggestions?
I have seen a lot of postings of people putting MB wheels in a Passat and the Passat I know for a fact is 5 x 112.
Also look here MB Bolt pattern
Originally Posted by bforbrian
So the question is, can a 5x114.3 fit on a Benz CLK (not the newer model)? I saw a picture of "5x114.3" on his CLK. He's positive that the rims are 5x114.3
More info
The guy did look at the back of the rims (sevas, S55 and S22) and it just stated the width of the rim and offset...
This is really suspicious cause he swears they are 5x114.3... yet they're on his CLK. It's not the present CLK model, it's the gen right before that--more rounded body. This is really weird
That site says the CLK is 5x112.
His CLK is year 2000. But he said that the rims were off by a mm.. does that mean that he really did put 5x114.3 ? I need to get to the bottom of this, i have a time constraint
I have SEVAS S22. 8.5x20, 10x20 with a bolt patter of 5.114.3 and 40 offset. They also come in 5x112 & 5x120. The only other offset on these wheels is +25. Are they selling the wheels that are mounted on the car or are they using that picture as a reference?
Ok .. think of this ... all evidence says the MB is 5x112 ... now he says the wheels are a mm off .. that = 113 which is wrong for everything ....
I think your at the bottom already... if the guy is in town go try one on .. if he is out of town and your doing it on line ... run ... .. if he is putting time pressure on it .. run faster ...
lol, ok here's the actual sale:
2 S-55s, and 2 S-22s. (2 on left and 2 on right, he loved both so he split up the models).
Fronts are all 20x8.5 and rears are all 20x10 with offsets of 40.
So the final verdict is: They are actually 5x114.3 but he made them fit on his 5x112. If 5x114.3 is bigger than 5x112, then he didn't necessarily "stretch" them, he just got bigger lug nuts? In any case, you guys suggest I run?
My only weak spot for his sale is that he's giving me all 4 rims with tires on them for 1000+shipping. I couldn't pass up this offer.
I wouldn't buy them unless I saw them ... I suspect there is wheel hole damage and if he ran them with bigger nuts he would have had clearance issues with the nut and the socket and the wheel bolt hole.
pretty much yeah, i think it's a nice variation haha they're both my fav models from sevas.
i just don't like the idea of him putting 5x114.3 on 5x112... sounds like he's trying to cheat me
I just did some drawing .. I don't think there is enough give in those holes to even fit over the bolts.
Thing you have to remember bout a deal like this is your not seeing them and if they are damaged from miss use etc or not even the right pattern your never going to see this guy again.
It depends on the offset.
Check this guy's threads, his running 19x9 all around.
https://acurazine.com/forums/showthread.php?t=169399
THOSE are NOT 114.3's
If it's too good to be true, it's NOT!
The guy has two different types of wheels on the car, VERY shady.
PS - I OWNED a 2001 CLK55 just prior to my '04 TL and I can tell you FOR A FACT that the wheels from a CLK will NOT fit a 3rd Gen TL, PERIOD! I can also tell you that the E-series (even the older model ALSO used the 112 bolt patterns). I can ALSO tell you that 20's "DON'T FIT on the CLK's" but they probably "could" fit on an E-Class. I had rolled fenders (all TRUE AMG's come with rolled fenders) and there was no way in heck to get them in there. So, the guy is trying to scam you
Here's a reputable Benz link
http://forums.mbworld.org/forums/forumdisplay.php?f=44
Applicable quote from that site where a guy was trying to use some 114.3's on his 2000 E-Class...
"Hmmm...I've never come across bolt adapters for 5x114.3 to 5x112. (I've seen 5x100 to 5x112 or vice versa, can't remember which way they went.) Don't think it's going to happen, sorry. Your best bet is probably to sell those wheels and just get a set of 5x112 wheels for your E-class"
http://forums.mbworld.org/forums/sea...archid=3455280
FYI.. aside from bolt pattern.. which, is almost impossible to put 5x112 on a 5x114.3 or vice-versa without damanging or modifying the wheel...
Benz's are RWD, so you are probably looking at a lower offset (20's, 30's..whatever)
dont do it man!
hell, if you wanted MB wheels, you should have bought my ASA's lol.. perfect replicas...
dont do it man!
cycdaniel
12-17-2019 10:58 AM
darksky
09-05-2015 03:11 AM
