Ace Arius 18x7.5 Advice needed
Ace Arius 18x7.5 42 offset w/ Eibach Prokit drop
will this rub on my 03 tl-p?
here's a link to pic
http://www.wheelmax.com/Wheels/ace/ace.htm
thanks
thanks
you will rub! anything under a +45 offset and running a 225/40/18 will rub. So now that you have a +42 offset AND your planning on getting 235/40/18........there is no doubt that you will DEFINATELY RUB!! don't buy those! look for something with a higher offset. I think if ur planning on going with a 235 tire, u need at least a +48 offset, and if ur running a 225 tire u need at least a +45 offset. Hope that helps! good luck!
Re: Ace Arius 18x7.5 Advice needed
thanks
thanks
ADR M-Sport. These are a little different mesh but they come in +48mm offset. I think a 7.5" wheel will have thinner lip. A
I see alot of members with 18" RH Evo's. These all come with +42mm offset. Do they all rub or shaved the fender so they won't?"
"I think if ur planning on going with a 235 tire, u need at least a +48 offset, and if ur running a 225 tire u need at least a +45 offset."
If you do the math the 235 & 48mm will be the same as 225 & 43mm. 235 is 5mm wider on each side -48mm=43mm.
Soul_Deamon
11-13-2018 04:44 PM
BobbyGraham388
10-22-2015 05:05 PM
