A_SPEC Suspension Alignment Specs
Old Nov 4, 2008 | 07:16 PM
K_Johansen's Avatar
been searching for the most up-to-date A-SPEC suspension alignment specs for an 06 AT...and have been for the most part unsuccessful! found a few links for 04s but didnt know if those are the same for the 06s. any help would be greatly appreciated!!!
Old Nov 4, 2008 | 07:29 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
-1 degree camber all the way around
0 toe all the way around
Old Nov 4, 2008 | 08:20 PM
K_Johansen's Avatar
do i need a camber kit then? i thought the camber is non-adjustable on acuras? i could be wrong, im new to suspension mods and just going by some other posts?
Old Nov 5, 2008 | 08:12 AM
Trew's Avatar
Your tires will tell you if you need a camber kit. If you're wearing too much on the inside and your toe is within specs, then yes, you probably should get a camber kit to bring camber out a little and take the stress off the inside of the tires a bit.
Yes, you are correct. Camber is not adjustable on a TL. Thus the reason for the camber kit.
Old Nov 5, 2008 | 08:32 AM
94 DC4 RS LSV/Turbo
camber kit is not mandatory as stated in this thread
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/do-i-need-camber-kit-606757/
Old Nov 5, 2008 | 09:14 AM
jmkiang's Avatar
zaino'd
^ Buying mine today
Old Nov 5, 2008 | 11:42 AM
K_Johansen's Avatar
^camber kit or suspension? if suspension look on ebay, $520 shipped!
Old Nov 5, 2008 | 12:33 PM
jmkiang's Avatar
zaino'd
Camber kit. Can't find the Ingalls one on eBay
Old Nov 5, 2008 | 07:14 PM
AndrewA's Avatar
I don't know if the alignment specs would be different for the 06 compared to the 04. I know you said you found the 04 specs, but here's what I found in case they are any different than yours.
Remember 60 minutes in a degree.
A-spec alignment numbers:
Front Camber: - 40 minutes +/- 30 minutes
Front Caster: 3 deg. 17 minutes +/- 45 minutes
Front Toe: 0 mm +/- 2 mm
Rear Camber: 1 deg. 20 minutes +/- 30 minutes
Rear Caster: N/A
Rear Toe: 2 mm +/- 2 mm
Old Nov 5, 2008 | 07:28 PM
AndrewA's Avatar
Ooops Sorry. Rear Toe should be 0 mm +/- 2 mm
Old Nov 5, 2008 | 08:17 PM
BREALKID's Avatar
5th Gear
Hotness
Old Nov 5, 2008 | 10:16 PM
lenjaiah's Avatar
are these specs for all aspec's? 04 to 08?
Old Nov 6, 2008 | 06:44 AM
AndrewA's Avatar
I should add that after installing my A-Spec suspension, I got an alignment and my rear toe was 0 degrees, both sides. Rear camber was -1.2 deg and -1.4 deg respectively. I started getting some cupping on the inside edge. I'm going back to re-inspect the alignment and if everything is the same, I'm going to invest in the camber kit.
Old Nov 6, 2008 | 12:10 PM
Trew's Avatar
Cupping?
Cupping is usually caused by worn suspension parts, not a bad alignment.
Cupping is circular spots of wear on the inner or outer edge of a tire. If that's what you're seeing on your rear tires, then you should check your suspension for worn parts, assuming you bought the A-Spec suspension new and not used.
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
jsonkimz
Mar 28, 2016 07:49 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
4drviper
Sep 23, 2015 07:42 PM
