7.5 vs 8.0 width rim and tire on '06 TL
my 06 acura tl came from the dealership with after market 19inch zenettis. one broke so now i pretty much need to get 4 new rims. but i need some help.
i have narrowed it down to 2 rims, 08W18-SEC-200B (dark chrome a-spec 18x7.5) and 08W18-SEP-202F (dark chrome 18x8.0).
as far as i can tell the 200b was originally made for the tsx, but fits the TL. and the 202f seems to be made for the 06-08 TL.
my main questions:
1) are there any disadvantages to going with the 7.5 inch width (since its cheaper) vs getting the 8.0 inch wide rim
2) what is the best tire size for each ( i like having a bit of a bulge so the tire sticks out a bit beyond the rim to protect it when parallel parking)
i am in a bit of a hurry to get my car fixed so all help is really appreciated, i want to be able to order the right rims and get them on ASAP.
thank you,
carlos
p.s. i do have tpms, but i have been told that the tpms will work on pretty much any rim.
my main questions:
thank you,
carlos
3G TL/2G MDX Owner
^^what they said. i believe the 7.5 inch width is for the TSX.
18x8 is OEM spec for the TL with 235/40/18 tire size. you can go 245/40/18 to give you your extra rim protection...there are threads on this for aftermarket tire sizing.
amirite?
I wouldnt go less than 8" width personally. In fact I use to run 18x9.5s on my old Maxima and they grip was awesome
Stay Out Of the Left Lane
Received 1,241 Likes
Like others have said, I wouldn't want to go narrower than 8.0".
As a recap: stock OEM rim is 17 x 8 and tire size is 235/45 R17.
I use the link below to compare tire sizes and what they will do to your speedo, etc...
http://www.1010tires.com/tiresizecalculator.asp
Also there are many threads on AZ about different sizes which will with and why you should use / try them. Based on one of the threads I found -
https://acurazine.com/forums/showthr...uot%3B255%2F40
I ran 255/40 R17 on my stock rims and was very happy.
Here are some other threads for your reading pleasure.
nuldabz
09-03-2015 05:49 PM
