6speed Motor mount question... PLEASE!!
Old Jun 25, 2012 | 10:31 AM
XxAfG786xX's Avatar
Talking 6speed Motor mount question... PLEASE!!
well i need to replace all my motor mounts on my 2004 TL 6speed.
does anyone know the part numbers for the side, rear, front and trans mount??
i noticed that Automatics have a different trans mount number is that the only one that would be different from a auto and a manual?? and the rest of the motor mounts should be okay correct??
Also whats the vacuum line going into the front and rear mounts for?? can that be blocked off??
any help, answers, pics or links is appreciated!!
Old Jun 25, 2012 | 11:05 AM
ez12a's Avatar
the overexplainer
the vacuum lines to the mounts are to stiffen them when the engine starts up, if I remember correctly. There's a solenoid in the engine bay near the firewall that control them. I would imagine this operates on the vacuum generated during startup high idle which is why you may feel more vibrations in the first few seconds.
Why not go with urethane mounts from one of the vendors? It's unfortunate they dont sell them individually otherwise I'd replace my side mount with one.
I read in earlier threads the MT mount is a bit more tough than an automatic due to the increased stresses of clutch engagement. Better stick with the MT mounts if they're different.
Old Jun 26, 2012 | 10:45 AM
XxAfG786xX's Avatar
thank you.. any links to aftermarket mounts?? dont want to spend alot as im going to be selling this car once complete
Old Jun 26, 2012 | 02:01 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
Aftermarket motor moUnts is a big no no...oem or nothing,unless your going peformance...
I had an 03 accord once I bought all three motor mounts aftermarket my car was shaking more with the new mounts..lol
I had to take them off and buy oem..
Check out rockauto.combfor aftermarket part,but I wouldn't recommend buying aftermarket mounts....
Acurapartsworld.com sells oem parts at discount with free shipping
Old Jun 29, 2012 | 07:47 AM
XxAfG786xX's Avatar
your the man!! thanks for the suggestions
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
STL TL-S
Sep 23, 2015 08:52 PM
