5MM spacers....Are longer studs necessary??
ahhh yes, I feel like an ass because I just found a thread that answers my question. Seems like the consensus is "no"......Has anyone tried and found that is IS necessary to have longer studs?
Do I need one that is hubcentric or will it wobble otherwise? 64.1mm, am I correct? Does it have to be secured onto the hub or is it simple held in place with the tightness between the hub and wheels created by the tightening of the lugs?
geesh I sound like a noobie, lol.
Of course anything +5mm would require studs, I wouldn't chance it in that case! I just feel 5mm is so close to nothing, it's almost like a piece of cardboard in there. I'm quite sure the lugs will get plenty of turns. Thanks for the offer on the spacers but I don't want anything thicker than 5mm.
We are all speculating or guessing here. I guess what I am really asking is whether anyone has ever done 5mm spacers without studs and ever experienced any negative effects?
I also wonder whether the requirement that something should "hubcentric" is dependent on the hub design or the wheel design? If it is the hub then nobody would ever require rings but I have heard of many requiring in certain applications. Why is this?
OK so the spacers are on and yep they are as thin as cardboard and hardly make a difference. I still get about 3 turns out of the lugs and it is plenty tight. I'll retorque after a few miles, should be fine.
My only prob is the tires are rubbing more now........ughh, I always ask for trouble... 1 nagging problem after another....
Received 6,470 Likes
Rocky, let's see some pictures!
Hehehe didn't do it for the wider stance really. It makes the rear look a LIL wider. Camber changed negligibly. Ordinarily a 5mm spacer does nothing except to allow so additional clearance for the wheel or brakes....I did it to fit a mod something to do with my rear brakes........lol, I think Al knows what I am talking about, just haven't advertised about here on AZine. I raised the rear 5mm already and I don't want to go higher, it's sitting perfectly. My fenders are rolled already, I'm goin outside right now as a matter of fact to see where it's rubbing and I'll make small adjustments to clear the tire. It's really only 1 tire the other is OK unless people are sitting in the back. It's real annoying because it rubs on every little dip on the road. I will take some pics, but I promise it ain't anything you guys haven't seen already.
My rear fenders are already rolled but I still rub. When I removed the rear wheels and looked around I can see where it is rubbing. When the car is lowered most of us know that it causes negative camber...Now this is not a bad thing, at least when it comes to rubbing issues. It helps the tires tuck in a bit. Putting the spacers in negated that benefit. OK but that is not all! What most people don't realize is that CASTER also changes! That's the reason why when you look at side pics of a lot of our lowered cars the wheels look off center in the wheel well.
Well my fender was not rubbing where you would think it would rub. It was rubbing more to the REAR part of the fender. I took thick layers of duct tape and a metal chisel to hammer over and bent the fender a bit. (I know hammering a fender is a big no-no but I didn't feel like driving out to pay for another fender roll.) I risked cracking the paint of course but all was well, I was careful, and nothing happened. As a matter of fact there were other tiny areas that were rolled previously (With a professional fender roller mind you) that have ended up cracking slightly over time. They weren't cracked when they were rolled....I dunno, temperature changes?? Well I sealed all rubbed cracked areas with silicone.....I know that is temporary and won't last the sandblasting from the wheel well. I might have to buy some of that rubberized undercoating spray to inhibit rust/damage there.
Well anyways, bottomline; I got spacers on and NO rubbing!
OK some pics as requested:
Spacers are so thin. Really not much of a difference
Now that is as flush as you can get! PERFECTION!
That's my kind of beautiful
Rocky, DAMN !!!!! HOT !!!!
I forgot you cleared your front grill, and I've always loved the carbon fiber Aspec lip. But the wheels and tires are over the top!
Retired!!! ON TOP!!!
You are rubbing in the rear fender near the bumper... that's where most of the TLs Rub... I don't think that the dude that rolled your fenders pushed that section flat... because the roller doesn't go that low... you actually have to heat it and hit it with a mallet... Do it yourself rocky... it's very simple...
Good Luck and as always our car is just DOPE!!!
Originally Posted by flip_side
id go a little lower in the front imo
I was in the Bronx the other day driving like 15mph and my car was hitting everything. At one point my J-pipe scrapped!! I had enough, that is way too close to the oil pan!! Tires are sliced to all hell.
Last week I raised the rear 5mm and the front about 10mm. Right now it is barely enough to drive somewhat normal. My car is a daily driver doing 150 miles a day. I have to live with this compromise. Gotta move to Miami for this car!
Yesterday some girl in front of me pulled too far into an intersection and backed up into me. It wasn't a hard hit but that's it! I am buying a beater.....maybe an ol GTI just for commuting. I'll slam the car and leave it in the garage for weekends. I put too much into it for it to get beat up.
RPF1+RS3 FTW
Rocky your car looks sick with Faiz's old wheels. I was so tempted to buy those. BTW I rub in that same spot in the back like near where the rear fender meets the rear bumper. I have rolled it twice and pounded it super flat and cut the tab and it still rubs back there lol
rims
what kinda rims are thos i looked up a spec gun metal but they arnt the same ones?
[/quote]
[/quote]
