? for 5AT'ers with A-Spec Suspension
Old 10-17-2004 | 03:07 PM
Treblig's Avatar
Did any of you opt to also add the thicker front and rear stabilizer bars that come with with 6MT suspension. Is there/would there be any value to adding them too??
Old 10-17-2004 | 04:02 PM
neuronbob's Avatar
I'll move this to Suspension. Before I do, I'll answer your question.
I didn't upgrade the sway bars yet but plan to. While there is some benefit to upgrading the thicker front sway bar (the 6MT's is not much larger than the 5AT's, 27 mm vs 25 mm), there is more benefit to upgrading the rear sway to the 22 mm Comptech rear sway bar (6MT is only 20 mm vs. 5AT's 17 mm); reduces understeer and reduces body roll as well.
HTH.
Old 10-18-2004 | 03:35 AM
dtakai's Avatar
He said it perfectly. As for myself, I did the aspec with just the comptech rear sway bar.
Old 10-18-2004 | 08:57 AM
Treblig's Avatar
Is the Comptech a direct bolt on? How much of a handling difference have you gained?
Old 10-18-2004 | 10:33 PM
Treblig's Avatar
Anybody????
Old 10-19-2004 | 03:02 AM
dtakai's Avatar
Yes, the Comptech is a direct bolt on. More acurately, the Comptech rear sway bar will replace the stock rear sway bar.
The body roll as a whole is definately less, so the car stays much more flat through turns. This reduction of body roll comes at the expense of a little more bumpyness in ride. But not too bad. Also, by stiffening the rear suspension, the understeer is reduced making turn in more neutral. If all of this does not make sense to you checkout these for basics:
http://www.chris-longhurst.com/carbi...ion_bible.html
http://car.lifetips.com/cs/Car/Car-P...dling/Tips.htm
Old 10-19-2004 | 11:12 AM
Treblig's Avatar
dtakai, thanks for the great links..
Old 10-19-2004 | 08:59 PM
neuronbob's Avatar
Awesome links, dtakai! Points for you!
Old 10-22-2004 | 01:27 AM
EluSiOn's Avatar
HTH.
how much is the 22 mm Comptech rear sway bar do you know the exactly part number for it?
Old 10-22-2004 | 03:40 PM
neuronbob's Avatar
http://www.comptechusa.com/store/product412.html
$110 from them. You can order it from some Acura dealers, too. If you search, you'll find some excellent reviews in this section from those who have installed it. I plan to as well...eventually.
Old 10-23-2004 | 12:16 AM
EluSiOn's Avatar
thank you neuronbob
Aspec Suspension is about US$ 700 from http://www.acuraparts247.com/
Comptech rear sway bar US$ 110 from http://www.comptechusa.com/store/product412.html
Dealer Labor/alignment US$ 390
total should be around US$ 1200 right?
MrHeeltoe
20
02-23-2023 02:54 PM
MrHeeltoe
09-29-2015 11:43 PM
adreano17
09-29-2015 09:48 AM
MrHeeltoe
09-28-2015 06:43 PM
4drviper
09-23-2015 08:42 PM
