4 bolt rim??
4 bolt rim??
I was just about to order my rims and then I realized something might be wrong. The rims that I want to order have a 4 bolt pattern and I have no idea if they would fit for an 06 TL.
http://www.carid.com/msr-wheels/045-112689.html
Once you get on this site, its the second rims for the pictures the dark one with a 4 bolt pattern. Does anyone think they would fit for my TL?
Your Friendly Canadian
Received 1,491 Likes
This is too easy...
Resident Dingo
Is this a serious post? No, they will not work.
Also, those wheels are garbage. When you get wheels, buy forged wheels. They're more money for a reason. They won't bend or crack when you hit pot holes and other crazy stuff you may unexpectedly come across while driving.
Jokerman
to be honest you should have already knew that we cannot do a 4 lug wheel. But from what i understand about that site is that they make each set of wheels when they are ordered. Do i believe that? Not really but if you look throught those pics, they have 5 and 4 lug design. Contact the company and ask them directly if you want to order the rims.
Soundmaster28 do some research. You will be fine. Through trial and error you will find everything you need. Your better off just going to a rim store and test fitting some rims. Listen to what thedingo said about quality wheels but IDK if your ready for forged rims. Just get your bolt pattern right first.
CLtotheTL32 (10-03-2011)
Jokerman
Also, I think you probably quoted the wrong person, becasue i never said anything about the wheels being good or bad.
Resident Dingo
^ lol
Good, quality wheels are forged from a block of billitt aluminum. They will be much more solid and resistant to bending and cracking. Wheels, like these, that are 4 for $500 are cheap for a reason. Save yourself the anguish of buying more than once and get a good set of wheels, then hang on to them. I personally love my iForged wheels, but CCW and HRE are also wheels that I recommend as I have personal experience with all of these companies and their customer service departments.
Look for wheels that have a 5x114.3 bolt pattern. That will help you narrow it down.
Registered 3.5L Member
^ This
This. This site is information based. You guys flaming the OP need to tone it down alot. Soundmaster- thanks for being mature in your responses unlike the others in this thread.
^ lol
Chapter Leader (Houston)
^ lol
I was actually thinking that there is a huge gray area that's between the forged stuff and what OP is asking about.
Needing forged also depends on needing super light weight, the roads you're driving down, the type of tires you got on em (cheap wheels with a 70 series tire are probably fine)...to suggest going to HRE's...JEEZ!
Try
XXR's...they are a cheaper alternative but still seem to be decent quality. And of course...5 by 114 as mentioned.
Try
Resident Dingo
So you believed the Tire Kingdom guy when he sold you bad ass wheels for $150 a wheel? What's the deal? Tell me I'm wrong and post some information to back it up. You really shouldn't post disinformation. Normally, I wouldn't even waste my time but YOU do not know what you're talking about.. Let me do my part.. read and learn.
http://www.tirerack.com/wheels/tech/....jsp?techid=90
http://www.esi-group.com/products/ca...ips/eTip16.pdf
http://www.corwheels.com/forged-vs-c...he-difference/
http://www.ehow.com/facts_6018344_fo...um-wheels.html
"Due to the immense pressure that the billet undergoes during the forging process, the metal is less porous compared to cast wheels and has an interlocking and aligned grain structure. Although this can only be viewed under a microscope, this structure results in improved strength, durability, and resistance to corrosion and oxidation. Due to the more consistent forging, the same structural integrity can be achieved using less material in a forged wheel versus a similarly designed cast wheel"
so that's why forged is better than cast?!?!?!?!?!
omg you poor poor noob
Resident Dingo
sarcasm, eh? (because you're canadian)
the point to be made was regarding a more significant structural integrity. i should have known to just let it be.. carry on.
'That's what she said!'
While I do agree that getting forged wheels is an excellent idea, I think there are other wheels (that are not forged) that a person can get that are excellent quality. I had Enkei EKM3 wheels before and I've hit some nasty pot holes here (NYC) and they were solid wheels, never bent on me. I have RPF1's now and I've hit some nasty potholes as well with these and they have stood strong. So while forged wheels are great, it doesn't mean you can't get great quality cast wheels.
