265 tire with 8.5" wheel?
So i am planning on putting 265/30/19 tires on a 19x8.5 wheel. I did some research and some(bmw and Evolution guys) say its fine and no problem while others suggest not to because it will bulge.
So i just wanted to know whats the opinion of folks here on AZ.
I guess im planning on doing the exact opposite of what the hellaflush people do
265mm and 8.5" is more than fine. I'm running a 255mm on the stock 8" rims. You added roughly .4" of tire width and your rims are .5" wider than mine.
Here are my 255/40/17 on stock rims. A 265 on an 8.5" rim will have even less "bulge" if you can really call it that.
Should be ok if you don't mess with the rear camber .. if you look at my car pix you will see I'm not slammed .. just dropped an inch and with then camber set closer to zero I don't have a lot of clearance and I'm on 235 - 35 - 19
Can you do it, yes, should you do it, no:
265/30-19 has a recommended wheel width of 9"-10".
Your choice. That setup will move the wheel 5/8" out farther towards the body, and the section width of that tire is 10.7", and slamming the body down..........
That's perfectly fine. The Acura bunch over here will suggest stretching a tire which is dangerous but not a 255 on an 8" rim which is far from dangerous and was a common ratio in the past.
I'm trying to decide which summer tire to buy in the next month, those look pretty beefy.
Try a google search and you won't find a single bad review.
sounds like they'll rub.... I have 245 on 8.5.... they look fine... but it sounds like the wheels will bulge out.... I think if you hit a pot hole fast enough, you'll probably damage the tire....
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
nuldabz
09-03-2015 05:49 PM
