245/45/17 on stock wheels
Has anyone have 245/45/17 on their stock wheels? I was thinking of getting this size for my 08 TLS.
Any issues at all in noise, fitment, rough ride, tire wear, etc?
AZ Community Team
Received 7,771 Likes
Lots of people.
No issues. It one of the two popular alternate sizes. The other 255/40-17.
You should search "245/45" and "255/40" - LOTS of threads; pics too.
'05 TL NBP/Ebony Auto
I'm very close to ordering the Continental DW 245/45s for my 05 stock TL. Liking the reviews/price on them. Will definitely post my reviews on them once I get a few 1000 miles. Check tirerack.com for sizes but you'll see they're so similar to the OEM 235/45s.. especially the EL42s that came on my TL.
I got my DWS on Wednesday from Discount Tire. They had to order them and it took just a few days to come in. They are 255/40/17 so the size difference may have some to do with it. If so, just get the 255's, they're healthier btw I used to live in north Austin around Parmer Ln
I got Michelin Pilot Sport A/S Plus in 245/45/17 on my stock type-s installed a few months ago. In the rain, I feel much more confident in these things compared to my stock Bridgestone Potenza summer tires (expected... it's a summer tire). In dry weather these tires are definitely a DOWNGRADE in performance. The 245/45 tires are too big in diameter and the sidewall has too much flex to allow me to take corner as well as I used to. My mpg went down ~1mpg and I believe my car is a bit higher than it used to be. This is only speculation, but I believe that the higher center of gravity + the taller, less stiff sidewall are the two things contributing to my loss of performance.
245/45 tires are great for those of you who aren't performance mind oriented, but keep in mind that my tires DO rub on wide turns (Keep in mind that i'm lowered 1.4" on H&R sports + Koni SP3s). The tires touch the inner plastic of the backside of the plastic fender lining. If you're looking to retain good handling, I'd suggest going with a 245/35 or 235/45.
AZ Community Team
What pressures are you running?
FWIW, the Bridgestone 235/45 you were running is only 1/10 inch (2.5mm) different in radius than this 245/45. IOW - the sidewall is only 0.10 inch shorter on the OE tire.
235/45R17 25.6"
BS-Not certain of the exact summer tire that was the option, but the RE030 93W is 25.5"
A 245/45-17 is 25.7", so looking at the sbove numbers, this would add .1" or .2" to the diameter when compared to stock dimensions, or only .05" or .1" to the radius. If the 245 rubs, I'd say there is another problem as we're only talking about a 1.3 mm difference.
The section width on the Pilot A/S 245/45-17 is 9.6", the same as the OE HXMX4 and only .2" over the RE030, or .1" more inner and .1" more outer.
AZ Community Team
You have to look at the specific tire.
lumyeinjun says he was running OE summer tires (BS RE030 235/45-17). Diameter = 25.5". (Section width 9.4")
He's now running Michelin Pilot Sport AS+ 245/45-17. Diameter = 25.7". (Section width 9.6")
So 0.2 inches on the diameter is 0.10" on the radius, which is the sidewall difference.
I'm just not sure 1/10th of one inch on the sidewall accounts for all the difference lumyeinjun says he feels. Maybe it does. But maybe tire pressure is also a factor.
I also note lumyeinjun says the RE030 are poor in the rain which is "expected <because> it's a summer tire." But my experience is that "good" summer tires grip in wet and dry.
I've actually hyrdroplaned in the rain over here in So cal a few times . Bearcat, are you running the OE summer tires? Any problems in the rain?
The Michelins definitely fill up the wheel gap more, but I've found that the tires tend to chirp when taking corners the way I used to with my factory Bridgestones :/
I'll try to get a picture of my wheel/tire setup up later this week.
Sorry for kinda hijacking your thread OP, I forgot to mention that it'll probably depend on which specific tires you go with if you decide to get 245/45/17. I went with Michelin Pilot Sport A/S Plus and there is a noticeable reduction in road noise when compared to my worn OE Potenzas. However, my Potenzas were pretty quiet before ~20,000 miles and I haven't driven very much on the Michelins yet so it's hard to say. Theoretically, the bigger size should be less bumpy because you have a bit more rubber to absorb road imperfections. Ride feels nice and comfy to me Too early for me to make a comment on your other concerns though, only thing I have to complain about is the slight rubbing during wide turns (probably not an issue if you're not lowered) and my wheels chirping when taking turns that I used to take without having my wheels chirp.
AZ Community Team
I'm running 40psi in the front and 38 psi in the rear (cold temps).
I've actually hyrdroplaned in the rain over here in So cal a few times, I wonder why we're having such different experiences with the OE summer tires .
I didn't mean the summer OE tire specifically, but summer tires in general. The BS RE030 are generally poorly rated all-around. I'd rather run a summer tire - Michelin PS2's or maybe Conti DW, maybe even GY F1.
My Michilen's are "chirp-y" too. But noise, in and of itself, doesn't mean less traction.
I thought the 245's looked tall too when I first put them on. Then I realized I had run about 8/32nds of tread off the previous tire. That's a quarter inch on the radius (1/2 inch overall). So of course the new tires looked bigger - compared to what I'd been seeing the previous several months.
Regardless, hope you find a balance you're happy with.
Well, you're definetly running enough pressure. For autox, SCCA recommends about 5psi over normal.
1fatcrxnem1
22
06-01-2018 01:23 AM
mtl_ilx
09-03-2015 09:58 PM
