245/45/17 on stock rim and aspec shocks
Hi,
Im concerned of this since and the aspec springs. Will these rub? Will I have any problems? I just finish ordering and they told me that it will be a wider and taller....just concerned cause my car is lowered with the aspec kit.
grodri02 (02-10-2012)
justnspace (02-10-2012)
i'D DO 245/40... Here's why... A 245/45 tire will be taller than a 235/45 tire. Dropping to a 245/40 puts the tire closer to the height of the stock size which will also keep you speedo as accurate as it would be stock.
Better do some research. The stock Michelin 235/45-17 is 25.6" tall and most tires 245/45-17 are 25.7" tall, but dropping to a 245/40-17 will yield a tire height of only 24.8", about 1" smaller than stock, or just slightly taller than the height of the A/T compact spare. If you read, the 255/40-17 tire comes in at only 25", therefore a 245/40-17 would definitely need be be smaller than 25".
AZ Community Team
Received 7,770 Likes
Most 245/45-17 are very close to the stock tire diameter (as Turbonut shows) and won't even be close to rubbing with the A-Spec susp kit.
1fatcrxnem1
22
06-01-2018 01:23 AM
mrkingstonvi
02-22-2016 01:53 PM
