245/40-18 Tires on A-spec??
Old 03-28-2011, 07:18 PM
packohotdogs's Avatar
Hellooooo Everyone,
So I am in the market for new tires, and am thinking about going to 245/40-18.
Question is:will the 245/40-18 tires fit OK on the 18x8 A-spec wheels on an A-spec suspension (A/T) without rubbing?
Any negatives with this setup?? Thanks in advance...
Old 03-28-2011, 08:10 PM
Turbonut's Avatar
That's the size! No problems.
Old 03-28-2011, 08:15 PM
B A N N E D
Ricky Pounds's Avatar
On an 8 inch I would go with 235-40-18.
Old 03-28-2011, 10:26 PM
Team SSM
SSMTL04's Avatar
i went 245-40-18 on my 18x8 aspecs. The tire provides some extra rim protection. Looks perfectly fine. 235-40-18 would just be flush with the edge of the rim, whereas 245-40-18 slightly goes over the edge of the rim. So it's just up to you whether you want a more flush look or not.
Old 03-31-2011, 08:26 AM
BuffBakerGA's Avatar
235/40-18 3.7" 12.7" 25.4" 79.8" 794/mi 60MPH 10000mi N/A
245/40-18 3.9" 12.9" 25.7" 80.8" 784/mi 59MPH 9878mi 1.2%
245 is the way to go...
Old 03-31-2011, 12:10 PM
ttribe's Avatar
Received 5,939 Likes on 2,930 Posts
I'm running 245's on my A-Specs just fine.
Old 04-04-2011, 11:53 AM
R1ck's Avatar
Is that for a-spec wheels 18x8" ? are you sure you are not mistaken with the a-spec wheels 18x8.5" ?
I need tires for my a-spec wheels 18x8" and I can't decide...
225/40/18, 235/40/18 or 245/40/18 ?
Whats the dealer recommendation for 18x8" wheels on an Acura TL 06 AT base?
Thanks!
Old 04-04-2011, 11:58 AM
A-SPEC 6MT
jrocka312's Avatar
The OEM specs were 235/40/18. I am currently debating my tire size right now... I am not trying to hijack your thread...but check out my thread over here talking about the same thing... https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/tire-assistance-spec-18-x-8-5s-810115/#post12778158
Old 04-04-2011, 12:03 PM
R1ck's Avatar
Originally Posted by jrocka312
The OEM specs were 235/40/18. I am currently debating my tire size right now... I am not trying to hijack your thread...but check out my thread over here talking about the same thing... https://acurazine.com/forums/showthread.php?p=12778158
Your thread is about tires on 18x8.5" wheels right?
I need recommendations for the 18x8" wheels..
Old 04-04-2011, 12:12 PM
R1ck's Avatar
My friend recommends me 225/40/18
can anyone tell me if thats a good fit for the a-spec 18x8" wheels on my Acura TL 06 AT base?
Old 04-04-2011, 03:20 PM
It's gonna give you a stretched look...
Old 04-04-2011, 03:36 PM
ttribe's Avatar
FYI - the A-Spec's were marked as "18X8.5" in 2004. In subsequent years, they were marked as "18X8". According to someone on this board (sorry, I don't have reference, it's been a while), an actual comparison of the two wheels determined that they weren't actually any different than one another. The extra .5 inch on the 2004 version was, allegedly, illusory.
Old 04-04-2011, 03:41 PM
Mr Marco's Avatar
Both 225 and 245 widths will fit on an 8" wheel. 235 is the proper section width and will provide the best handling.
Old 04-04-2011, 04:11 PM
R1ck's Avatar
thanks ttribe and Marco! Thats what I needed to know I will go 235/40/18..
This will result in a speedometer Difference of 0.317% too slow
Is that right?
Old 04-04-2011, 04:18 PM
R1ck's Avatar
One last question, do I need any spacers or they will perfectly fits?
The wheels: Hyper silver a-spec wheels 18x8" 45mm offset
The car: Acura TL 06 AT base
Old 04-04-2011, 04:26 PM
ttribe's Avatar
No need for spacers.
Old 04-05-2011, 03:31 PM
djflex167's Avatar
Is that right?
No as that the OEM spec tire size for the aspec wheels!! the reason why me and a lot of members in here go with the 245/40/18 is because of more wheel protection and they still look good on our cars when mounted. If you live in a Pot Hole free city then keep the 235 40 18 size.
Old 04-07-2011, 09:18 PM
05TLRIDER's Avatar
Perfect timing to find this thread as I just bought some 18x8 aspecs tonight (assuming payment was received). Can one of you guys running the 245/40/18's post a pic or link to a pic of your car so the OP and I can see what it will look like??
Old 04-07-2011, 09:26 PM
R1ck's Avatar
I went with 235/40/18! the recommended tire size for our car/wheel (a-spec 18" 18x8).. thanks!
Old 04-07-2011, 09:33 PM
Walk the walk
Shoot2Thrill's Avatar
That may be true, but I''m not sure. I have a 2004 Aspec 8.5 wheels and have run 255 on them no problem. I'm pretty sure the 2004 are 8.5 and it was reduced to 8 in later years. The 8.5 and 8 are different part numbers. Further, I run 245 on the stock rims and that is not an issue. Further, I will never go back to 235.
Old 04-08-2011, 09:58 PM
Team Anthracite member
PsychoRx's Avatar
I changed my ASPEC set up from 235/40/18X8.5 to 245/40/18x8.5 and have had no problem since 19K miles. Thats all I have run since losing the original tires. No complaints.
Old 04-30-2011, 08:47 AM
bkmdano12's Avatar
Hey 05TLRider., what did you pay for your A-Spec wheels? I just picked up a set of chrome 18x8 A-Spec wheels in the box last week.
Old 04-30-2011, 11:09 AM
05TLRIDER's Avatar
I bought mine from ACT05TL (vendor on the forums) and he was selling them for $800 plus shipping. Way better price than the buying them from the stealerships.
Old 05-01-2011, 10:37 PM
ajs800's Avatar
245/40/18 on 18x8 aspecs
Old 05-05-2011, 01:31 AM
daluvdr's Avatar
Does anyone have pictures of 225/40r18 on A-Spec wheels? I wanted to see what the "stretch" look really looks like. I have a set of used A-Spec wheels and my brother gave me a set of tires he had in his garage (225/40r18). Should I install these tires or shell out moola to get either the 235 or 245? Thanks for any input.
Old 05-05-2011, 07:53 AM
VQPower37's Avatar
use up whatever life u have with the 225s ... then when their life is over, invest in a new set of tires (thats what i would do) esp if it was all free
Old 05-05-2011, 08:31 AM
Tebaz06TL's Avatar
i run the same continentals, but seeing how they sit on the road world be nice also. like your wheels
Old 05-05-2011, 03:33 PM
daluvdr's Avatar
The 225/40r18's are brand new. My brother bought them for his IS250 but his car was totaled. Would it be too big of a gap since my TL is not lowered?
Old 05-05-2011, 04:12 PM
daluvdr's Avatar
My A-Spec wheels doesn't have the TPMS. Can I install the 224/40r18 w/out them?
Old 05-05-2011, 05:13 PM
Turbonut's Avatar
IMO, yes and yes. Put them up for sale and install 245/40-18 tires of your choice.
Old 05-06-2011, 08:29 AM
ajs800's Avatar
Old 05-06-2011, 10:42 AM
That is one clean, perfect TL sir!!
Old 05-06-2011, 10:55 AM
Tebaz06TL's Avatar
Cool
Old 05-07-2011, 03:15 AM
daluvdr's Avatar
Sold the 225/40r18. What do you guys think of the Hankook Ventus V4 ES H105 245/40zr18 on the A-Spec wheels? It is $155 per tire shipped from Discount Tire Direct. I don't drive too aggressively.
Old 05-18-2011, 12:54 PM
vai777's Avatar
I'm running 245-40 18x8.5s Michelin Pilot Sport All Seasons on my 2004 Aspec and the rear left tire rubs when I hit a bump. These are the gun metal finish rims.
Old 05-18-2011, 01:24 PM
jsonkimz's Avatar
Go with the 245 size. It's perfect in my opinion. The OEM tire size is a 235, but the OEM tire that Acura put on the wheel was a little larger than most 235's. So the 245's work great. You get a little wider look with a little more rim protection. In my opinion, it's the perfect tire size for an OEM setup.
PLEASE, please, please, DON'T get a 225 tire. I never understood the stretched tire look when going for an aggressive wheel combination, much less for an OEM setup.
The 245/40R18 will make you happy!
Old 05-18-2011, 08:21 PM
B A N N E D
I recommended you the 235/40/18, you made the right choice. Now I recommend you a 10, or at least, a 5 mm spacer with a 45 offset. Do this, try and get someone to lend you two 5 or 10 mm spacers, try them on one side and leave the other side without spacers...I believe you will go with the spacers! Let me know once you've done the sampling!!
Old 05-18-2011, 08:23 PM
B A N N E D
O, and with the 235 you will have more than enough protection for your 8" inch wheel. The 245 is better recommended for the 8.5" inch. I had the 8'5 and I ran them with the 245.
Old 05-18-2011, 08:50 PM
emeka206's Avatar
I have 245/45/17's on OEM wheels and I love the ride
Might switch back when i get different tires only because more people have 235's and i can get it for cheaper here on AZ
For your wheel, the 245 would be the better choice on the 8.5
Old 05-18-2011, 09:49 PM
jsonkimz's Avatar
A 245 series tire is recommended for anything width from 8" to 9.5". So he'd be fine if he decided to go with a 245. It might be better recommended for 8.5, but 8 is fine too. But there's no comparison between the protection. IMO the 235 doesn't really cut it while the 245 does much, much better. It's not like either is a bad choice though.
EDIT- The 245 gets my vote, but I will say that you will probably see slightly better mileage if you go with a 235.
Quick Reply: 245/40-18 Tires on A-spec??
