225/55/16 RE950's BIG MISTAKE
After hours of research on this site, with Acura, and with Bridgestone, i popped a new set of 225/55/16 RE950's on the car. so heres the story.
I get them installed, and drive off. In short, ive been back 4 times to get them balanced. Finally after road force balance, its a little better, but not much.
The tires, although everyone here and Bridgesont says they will work fine, are eating themselves alive. They are feathering and wearing rapidly. Their just too wide for the rim. I tottaly regret these tires. I just should have got the 215/55 Kumho 712's like i wanted to. The worst part is, the RE950's dont even perform that great. But they are great for rain. Their like "what water?".
So anyone have any suggestions for me? anyone have this problem and find a solution? the car is bone stock and this should have worked fine but its not. its terrible. please kill me.
Re: 225/55/16 RE950's BIG MISTAKE
No, they're not. Check any tire manufacturer's recommendations for approved rim width.
I have just over 7,000 miles on my RE950s. Using a tire depth gauge, I measured both the inside and outside part of the tread on the fronts. Both are just a tad over 8/32".
You must have a problem elsewhere.
1 Post
Sparky57 I see you have the RE950 mounted on the original factory wheel. I am looking some replacement tires for my 2000TL I have the optional factory multi spoke chrome wheel for my car.
I was just wondering what tires would fit on my wheels I did not wan't to buy new wheels again or go up to 17inch wheels. This tire rates #1 in the High Performace All Season Survey for Tire Rack. I wan't something better than the stock Michelin MXV4 that I have now. The car just hit the 36,000 mile mark yesterday & I use winter tires in the winter. I just need to start looking for replacements. So my question is for sparky57 or anybody else with some info. What size tire would I get if I stick with the factory 16inch wheel & go with the RE950??
Please explain....
What advantage is there to getting 225/55/16 size tires or other over stock 205/60/16? Isn't stock the optimum formulation? How is the ride affected?
I am not a street racer, only a commuter.
Thanks.
Thanks.
Moderator Alumnus
Originally posted by acur8
Please explain....
Thanks.
Please explain....
Thanks.
Please explain....
Thanks.
Please explain....
Thanks.
If you're happy with the stock tires, I'd stick with them.
1 Post
Back in 99 or 2000 MOTOR TREND or CAR & DRIVER did a test on the TL. They said the car needed more agressive tires than the stock Michelin MXV4. They said it would handle & even brake better.
