2005 Camber Kit HELP
First of all please bear with me. I am new to suspension and just need some personalized help. I used the search feature and am still a little confused.
So I've had the car for a week and love it!! The owner before me has dropped the ride slightly on SS Tein Coilovers. It is aligned and all that but it has a bit of negative camber. I need to get the car MD state inspected as well as getting the most life of my tires, so he said his mechanic said he needs a camber kit.
I see there is a ingalls rear camber kit but there are also just lower camber kits, that deal with the toe? Little confused on this. Why would I need both? Would the lower arm do its job? I seen people complain about the ingalls rear camber kit and want to know why. I just need a little guidance on it because I have no clue.
Thanks in advance.
Thanks in advance.
From that pic the camber looks ok. Take another pic from back side to get a better view
of the camber.
Also did you get it aligned and what are the camber specs? Then maybe you can get a
helpful answer and get you going in the right direction.
As far as the ingalls go there are many opinions on the reliability issues. I for one will
buy the ingalls and see for myself.
of the camber.
of the camber.
of the camber.
its nothing too aggressive. Just a little negative. I will take another tomorrow. I can check with the guy I bought the car from to see if he still has the print out. I'm just going off of what the align tech said to him. there is a little wear on the toe. I think that's why he said it.
can greatly affect the tire wear over neg camber.
our cars come with a little bit of negative camber.
if toe is set to 0, then you're good!!!
maybe, you should google what Toe and camber means.
post up your alignment sheet.
the picture you provided looks great!!!!!!!! no excessive camber!!
Former Sponsor
The 3G TL has negative camber from the factory. But you probably need an adjustable toe arm. The INGALLS kit is the best kit because it has adjustment for camber and toe.
http://store.excelerateperformance.c...5/i-60220.aspx
If you want a set you need a qty of 2.
-------Tim-------
^Ingalls Kit = two lower arms/per side. One for camber adjustments, and another for toe adjustment.
SPC rear camber arm=Upper arm with ball joint. (This is only for camber adj.) <-with that said you should still have enough toe adjustment with the stock lower toe bar.
There is a lot of info on this subject on here.........
Former Sponsor
I linked you to a rear kit. The front kit includes ball joints.
Call our shop to discuss. Or email me at sales@excelerateperformance.com
emailnatec
29
09-28-2018 04:27 PM
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
