19x9.5 in front?
5th Gear
19x9.5 in front?
Hello There,
Im new to Azine...I got 08 TL type S and im trying to run 19x9.5 Front and 19x10.5 Rear. I know I could fit 19x10.5 in rear with offset 38, but Im not sure what offset should I run for front, I wanna clear BBK and not rub the fenders...Please Help
B A N N E D
they have a option for fitting big brake kits.....
http://www.workwheelsusa.com/media/w...S_SPEC10A1.pdf
for the T1S
same thing with the VS's
http://www.workwheelsusa.com/media/w...-XX%20Spec.pdf
basically you have to select from the very right column in the links above
for the T1S
possible:
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/wheel-fitment-thread-specs-images-reference-802711/
After all the PMs I get on wheel fitment, I thought it would be resourceful to have a thread like this.
I know there is a thread created by stillhere153 regarding wheel fitment but I thought it was a good idea to start a thread with pictures and exact specs (diameter, width, and offset) to guide members in the right direction for ordering wheels for their cars. Mentioning current status of fenders and whether or not you have a camber kit and if so, how many degrees. Some like poke, some like tuck, and some like flush. Look here!
This can also be a good resource for how a certain brand tire stretches (for those of you into that kind of thing....
NOTE: No distant pictures please; only up-close outer rim and fender pictures. Again, NO side shots, those do not help at all.
Format example:
Front: 18x8.5 +18, 215/40-18.
Rear: 18x9.5 +19, 225/40-18.
Fenders rolled & slightly pulled in the rear only.
Camber kit: none.
My current wheels:
Front: 18x8.5 +18, 215/40-18 falken 512s.
![](http://img530.imageshack.us/img530/2655/20101217153340.jpg)
Rear: 18x9.5 +19, 225/40-18 falken 512s.
![](http://img522.imageshack.us/img522/3765/20101217153300.jpg)
In the past....
18x9.5 +45, 275/35-18 nitto invo's all around.
![](http://img166.imageshack.us/img166/8162/img6235800xs4.jpg)
Front: 19x8.5 +22, 215/35-19, dunlop direzza dz101.
![](http://img6.imageshack.us/img6/2769/img1178800.jpg)
Rear: 19x9.5 +22, 225/35-19, dunlop direzza dz101.
![](http://img6.imageshack.us/img6/8554/img1183800.jpg)
No camber kits, rear fenders rolled and slightly pulled.
Front: 19x9.5 +24, 225/35-19, dunlop direzza dz101.
![](http://img23.imageshack.us/img23/3374/img2190800.jpg)
Rear: 19x10.5 +22, 235/35-19, goodyear eagle F1 A/S
![](http://img43.imageshack.us/img43/6613/img2248800.jpg)
![](http://img189.imageshack.us/img189/7547/img2404800.jpg)
Front: 19x8.5 +22: Size already posted above but below is the best picture I have of this front set up:
![](http://img24.imageshack.us/img24/5015/img3238800.jpg)
Rear: 19x10.5 +36, 245/35-19 Falken 452.
![](http://img692.imageshack.us/img692/2426/img3266800.jpg)
Front & rear: 19x8.5 +36 all around, Falken ST-115.
![](http://img10.imageshack.us/img10/6931/img3466800.jpg)
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Format example:
Camber kit: none.
My current wheels:
In the past....
13203!
im on a 19x9.5 +25 all around. minor rubbing after lots of fender 'massaging' . still need a camber kit to get more negative up front so i can lower it more. it IS possible.
