19x8.5 rear 19x8 front
WHat the perfect tire size for these two differnt widths. I want my tires to be rounded not squared off. Lowenhart LD5's 2004 TL
1 inch = 25.4 mm
at 8", a 203mm tire to be as wide as the rim. at 8.5", it's 216mm.
these rim widths usually take a 225/235/245. so if you want rounded tire shoulders, you probably want a tire width less than my calculations. you would also want an aspect ratio even smaller than required to pull it off. this will probably translate into speedo reading/abs/mileage inaccuracies.
not sure why you are going this, but that's my $0.02.
THank you for your help I appreciate.
And tell me why I shouldn't stagger widths on a front wheel drive. I have two other cars I've done it on and it looks much better than looking at a side of a car and seeing the same thing.
I can see If the wheels are sticking out of the well.
Other Cars:
2002 vette conv. Navy blue/tan
19x8.5 Fnt
20x10.5
HRE 540r
2001 merecedes S500 Black/tan
20x8 fnt
20x8.5 R
Lowenhart LD1
Other Cars:
19x8.5 Fnt
20x10.5
HRE 540r
20x8 fnt
20x8.5 R
Lowenhart LD1
actually, 04s can take 8.5s (with a lower offset than what is needed on previous models) all the way around but he is opting for a narrower wheel up front. yes it's true the narrower tire will be on the driving wheels (but stocks are 8's anyways) and he cannot rotate, but it's up to him.
mcd314,
Both of the vehicles you have mentioned are rear wheel drive. They are meant to have a wider rear wheel b/c they are rear wheel drive. (I bet the looked good though!) TL's FWD, although it would probably look alright, it just wouldn't make sense.
I ended up with a 245 width tire for the 8.5" wheel all the way around. Anything else didn't "square off" quite enough.
Good luck and show some pictures when you're done!!
Thanks for your help and comments. I probably won't have any pictures for at least two months since I live in Jersey and it's still too cold and snowing all the time but I definatly will.
P.S. I've been told buy a friend who works at a rim store that he has put 20x8 in the front and 20x8.5 in the rear of a 04 TL. I asked if it was rubbing in the front at all. He said with the 20x8 in front with a small tire size he had no problems rubbing when he took it out for a ride. WHAT ARE YOUR THOUGHT ON THAT?
Mike
Mike
getting a new setup is dependent upon your stock setup. the overall diameter of the new one should closely match the stock one and that's to prevent the inaccuracies i mentioned earlier. the reason that guy might be mounting on a "smaller" tire is because the offset is all wrong! if you have the right offset then you can get the right tire size; however, there is a good chance getting 20s means not being able to get the same overall diameter as the stock and therefore having the inaccuracies. on the 04s, i believe an 8.5" wide rim needs at least a +45mm offset (with possibly a 235 tire) to prevent rubbing. i'm pretty sure that guy is slapping on something less than 45 and that's why he is using the smaller tire. basically that is how it goes and since i don't have an 04 and it being pretty new, i'm not well versed on it.
ask the guy for the offset(s) and we'll talk some more!
GÜNnµ ¡Ï
yeah post pics already!!!! well there is a guy in here with 04 TL . black with 20s... foose speedsters. LOOKS FAWKING HOT!!!! black rims also with polished lip.. check the picture thread one is Anthracite pictures and other is i think its called... Modded TL's...
blownby
08-31-2015 12:44 PM
