19 inch on 2004 tl
19 inch on 2004 tl
hi i ws wondering if i wanted to put 19 inch rims on my 04 tl.do i have to other things too??like cut the inside fender or somthing??i heard that installing rims take more than one step.can someone please tell me if i want to put 19 inch rims on 2004 tl what i have to look before purchasing tires..only bolt pattern and size??
um....yea....um...
Rather than give you a hard time, I will just answer quickly...19s will fit no problem, I am dropped on Comptechs with 19s w/o an issue. Yes, bolt patter is important as well as offset.
Originally Posted by jonniewaka
thanks vtech..for the info those a$$holes up there in the forums couldnt help cuz they KNOW TOO MUCH.soi guess they cant share,,thats only knowing no knowledge...shit heads
For 19's I'd recomend you get 19x8-8.5 with an offset between 40 and 45mm. I've seen as low as 38mm and as high as 48mm.
Originally Posted by automata
Relax Homeboy. The reason they were giving you a hard time was because you could have found the answers to your questions by searching.
For reference the regular wheel is 17x8.0 and 45mm offset with a 5x114.3 bolt pattern.
As automata stated, 19x8.0 or 8.5 will fit. 40-45 mm offsets ensure perfect fit. You MUST use the 5x114.3 bolt patterns.
If you have a manual there is the issue of caliper clearance. Even if a rim fits all the specs that we stated here, if the spokes travel inward, or just don't have enough room to clear the Brembos it will not fit.
Search in this sub-forum, there are plenty of threads about this.
a 45mm offset on a 8" will be different than a 45mm offset on a 8.5" rim.
if you don't go too crazy, your aspect ratio chosen should equate to stock tire height, or go one ratio taller. as example if a 40 aspect equates to stock height then you may want to try a 45 just to see if it will fill out the well better. and of course, tire height is a equation of tire width, aspect ratio, and rim diameter.
i use ([(width/25)*(aspect/100)]*2)+rim diameter = Tall(inches)
accuracy within a few hundreths of an inch due to my rounding off the inches-to-mm conversion.
Originally Posted by sparkz
Stock width is 8" and 45mm. So 45mm would be stock however 40-45 will do
Originally Posted by da_illist_onE
Will the wheels being larger (19") than stock make a difference in offsets, or is 45mm still ideal? Thanks for the help.
To give you an example, a person on A-Tl bought Axis Hiros in 45mm offset but the spokes did not clear the calipers. He then tried them with the 35mm offset and it fit perfectly. The only problem is that it is more prone to rubbing since it is not as "in" as the 45mm offset would be. (He has not reported any problems with his setup though).
Short answer: 40-45 mm is still ideal as long as the spokes/wheel design allows space for the Brembos.
emailnatec
29
09-28-2018 04:27 PM
InFaMouSLink
10-30-2015 09:43 AM
johnpancakes014
09-27-2015 12:58 PM
