18X9 40mm offset on '05 Acura TL base
Will 18X9 40mm offset fit on a 05 Acura tl base AT? As of now the car is still stock everything including the suspension. I will be purchasing a set of Megans full coilvers in the spring. I dont plan on rolling the fenders or any other stuff, so please let me know if this setup will work. And will this 18X9 40mm have issues with my suspension up front. Thanks guys!
The wheels will fit fine. Having problems rubbing depends on your tire size and how low you set the coils.
Ok, so the tire specs are Continental DWS 235/35/18 or 235/40/18. Will i have any issues? I want to makesure it clears the front base brake and also no fender rolling or rubbing issue.
Since you have 18s, you'll need to use a 40-series sidewall so the speedometer isn't thrown off. I would recommend a 235/40/18 since you're not rolling the rear fenders.
AndrewS
19
03-14-2024 06:59 PM
Soul_Deamon
11-13-2018 04:44 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
nuldabz
09-03-2015 05:49 PM
